  • 1.  MobileDBGeneration Errors
    Posted 4 days ago
    Good morning, community,
    I'm encountering an error during the MobileDBGeneration cron task. The data files are being generated successfully; however, I'm seeing the following errors in the CORN pod logs.
    Has anyone experienced this issue or know what might be causing it?
    Line 309594: 16 Nov 2025 00:05:34:381 [ERROR] [MXServer] [] MMDBLog - MobileDBGenCallable.getData - Make LD Tree - ASSET - MBL_1611
    Line 310725: 16 Nov 2025 01:03:21:125 [ERROR] [MXServer] [] MMDBLog - MobileDBGenCallable.getData - Make LD Tree - ASSET - MBL_1729
    Line 312869: 16 Nov 2025 02:04:56:856 [ERROR] [MXServer] [] MMDBLog - MobileDBGenCallable.getData - Make LD Tree - ASSET - MBL_1766
    Thank you
    #Analytics
    #Architecture
    #CivilInfrastructure
    #HSE/OilandGas
    #Infrastructure
    #IoT
    #LifeScience/Calibration
    #Linear
    #MaximoForAviation
    #Nuclear
    #Procurement
    #Scheduling
    #Security
    #ServiceProvider
    #Spatial
    #Transportation
    #Utilities
    #WorkCenters
    #MaximoVisualInspection
    #Predict
    #Monitor
    #Health
    #Assist
    #Safety
    MARK FRITZ
    GM
  • 2.  RE: MobileDBGeneration Errors
    Posted 4 days ago
    This one should be able to be safely ignored. I reported it and it's DT Known Issue: DT452691 but it is wrapped in a try catch and shouldn't cause any issues with the preload job.
  • 3.  RE: MobileDBGeneration Errors
    Posted 3 days ago
    Thanks for the update Steven.
    MARK FRITZ
    GM
