The snap files, configdb, & restorefrombackup are not needed for Maximo to operate so they can be deleted. Sometimes there is value in keeping the configdb logs because that data is not persisted in the Maximo database. On a few occasions I've looked back through configdb files to understand when something was done to potentially understand what may have gone wrong. For example, I've seen custom attributes get added that don't get added to a view that later cause issues as a customer starts to use that for the first time. The older those files are the less likely they are to be important, but they're often small enough and have some value that I don't typically worry too much about them.
Sent: 12-19-2023 04:49
Subject: Non prod server space high
Thanks, Steve.
I found most of the heapdump and jabacore files sre from 2018,19. Some snap files too. Also, some configdb and restorefrombackup files from 2018,19. Very few heapdumps or configdb files from this year.
So can you please suggest if the snap files, configdb, restorefrombackup files can be safely deleted? Those r all from 2018,19.
Trisha S
Tcs
Sent: 12-18-2023 15:17
Heap dump files are large and should be cleaned up. If you have anything recent, you probably should keep them somewhere and send them off to IBM support to analyze the cause of the heap dump to make sure you don't have an ongoing problem.
Sent: 12-18-2023 13:01
Our dev server has almost reached its entire disc space. I found that there are many heapdump files,snap files,configdb files stored from last 2, 3 years. Can we delete those to clear the space?
Any suggestions or alternatives ,that you suggest?
Also, is there any harm in deleting the mentioned files?
#Analytics
#Architecture
#CivilInfrastructure
#HSE/OilandGas
#Infrastructure
#IoT
#LifeScience/Calibration
#Linear
#MaximoForAviation
#Nuclear
#Procurement
#Scheduling
#Security
#ServiceProvider
#Spatial
#Transportation
#Utilities
#WorkCenters
#MaximoVisualInspection
#Predict
#Monitor
#Health
#Assist
#Safety
Trisha S
Tcs
