Folks,
Many years ago, I would load WORKORDERS with MIF and if I had the PMNUM populated it would actually update the PM dates and such and also tick the PMCOUNTER. I seem to no longer be seeing Maximo tick the counter any longer.
Does anyone know if IBM changed that behavior and stopped this from working any longer? Or might it be a bug in 7613?
When I needed to get around the PM being updated, I used to have to load my data with my PMNUM in a place holder column, load with MIF and then use an update to move the value into the PMNUM. Was a hassle but worked.
Here is my system information:
App Server IBM WebSphere Application Server 9.0.5.10
Version
Tivoli's process automation engine 7.6.1.3-IFIX20230628-1738 Build 20220823-0909 DB Build V7613-344 HFDB Build HF7613-101
IBM Maximo Application Framework 8.8.0 Build 20220823-1257 DB Build V7600-23
IBM Tpae Integration Framework 7.6.1.3 Build 20220823-0909 DB Build V7613-61
IBM Maximo for Utilities 7.6.1.0-20230609-1234 Build 20230609-1234 DB Build V7610-09 HFDB Build HF7610-16
IBM Maximo Spatial Asset Management 7.6.1.1-20230615-1651 Build 20220818-2016 DB Build V7611-24 HFDB Build HF7611-14
IBM Maximo Asset Management 7.6.1.3 Build 20220823-0909 DB Build V7611-01
IoT Connection Utility 7.6.0.4 Build 20220303-1642 DB Build V7604-01
Server OS Linux 3.10.0-1160.92.1.el7.x86_64
Server DB Oracle 19.0 (Oracle Database 19c Enterprise Edition Release 19.0.0.0.0 - Production)
Thanks in advance,
Miller
#Administration#Integrations#Utilities------------------------------
David Miller
