Hi Prashant - thanks for the reply. We were setting the Where Clause to one record as a test, which is why they were the same. Normally the setWhere would have been including multiple records.
Anyway: I figured it out. We got clobbered by a newbie mistake, i.e.
matuseid=MatUseSet.getMbo(i).getInt("SERVRECTRANSID");
SERVRECTRANSID is a BIGINT data type, so it doesn't really work to try to use "mbo.getInt()" as a method to retrieve the value. Apparently if you do that, and the value is small enough, Maximo will do an implicit data conversion from BIGINT to INT. That's what it did in the other databases. But if the value is large enough, it won't be able to do that, of course. Unfortunately Maximo wasn't SAYING the value was too large - it was just returning a negative number.
We changed it mbo.getLong(), and it was fine.
Shannon Rotz
InComm Solutions Inc.
Sent: 06-07-2023 10:18
Subject: Problem exporting receipts from autoscript
In your script, There is a hard coded value of servrectransid, have you checked if this ID exists into DB of 3rd system?
MatUseSet.setWhere("servrectransid in (21316318062) ")
Also, not sure why you are fetching again servrectransid matuseid=MatUseSet.getMbo(i).getInt("SERVRECTRANSID"); when you already have it and hardcoded in line above
Sedin Technologies
#IBM Champion 2022
#IBM Champion 2023
Sent: 06-06-2023 05:48
We have the need to export a lot of receipts, one receipt at a time, from three different systems. We wrote an autoscript to retrieve the records via Where Clause, which we are then calling via the OSLC URL.
For two systems, this worked just fine, but we can't make it work on the third system. Two of the systems are the same fix pack (7.6.0.9) - one works, and the other doesn't. In the log, it looks like the autoscript is running, but nothing's happening. We've checked the usual things, i.e. the Publish Channel is enabled, etc. Can anyone help with this?
The script is:
from psdi.iface.mic import MicService
from psdi.security import UserInfo
from psdi.util.logging import MXLogger
from psdi.util.logging import MXLoggerFactory
from java.lang import System
from java.text import SimpleDateFormat
logger = MXLoggerFactory.getLogger("maximo.script");
logger.info("############## SCO Terminal Journals Exporting Started")
myMXServer = MXServer.getMXServer()
userInfo = myMXServer.getSystemUserInfo()
logger.info("############## userInfo = "+str(userInfo))
MatUseSet = myMXServer.getMboSet("SERVRECTRANS",userInfo)
MatUseSet.reset();
matusecount=MatUseSet.count()
logger.info("############## matusecount = "+str(matusecount))
for i in range(matusecount):
logger.info("############## Inside If = "+str(matusecount))
whereclause="servrectransid="+str(matuseid)+"";
logger.info("############## whereclause = "+str(whereclause))
myMXServer.lookup("MIC").exportData("DPWSCOSERREC","DPWGENGES",whereclause,userInfo,0)
Thanks in advance for any help.
Shannon
Shannon Rotz
