I think your question already contained the answer. The Multi-Asset/Location/CI thing is simply intended to make reference to a bunch of Locations, Assets, or Configuration Items (a Maximo IT thing) on a single Work Order, like if you wanted to know in great detail EVERY time an Asset had been touched, or what work is "open" / on a to-do list for a particular place or thing.
But it lacks the other features of Work Orders. You can't do much of anything to schedule these separately, assign them separately, track expenses separately, track the full status lifecycle individually (other than the simple checkbox to indicate completing it).
So if you need some of these "more advanced" features, don't use the Multi-Asset/Location/CI option when configuring the Route. Either use Tasks or full-powered Child Work Orders, depending on what all you need. With both Tasks and Child Work Orders, you can use a Job Plan, which means you can plan parts and labor usage, which means you can record actuals usage. MultiAssetLocCI lacks all this. It's intended to be nothing more than a simple checklist.
Sent: 08-15-2025 13:17
Subject: ROUTES: MULTI ASSET SPARE PART COST TRACKING
Hello MORE Community,
I recently learned about Multi Assets on a single work order by setting up a route.
My question is, how can I associate spare part costs and spread them over the multiple assets instead of the main asset on the work order (I'd like to remove the main asset unless it is required)?
When I issue an inventory item it issues to the main asset on the work order instead of distributing that cost across the multiple assets.
For example, if it is a route to change air filters in multiple assets. How can I spread the cost by how many air filters each asset needs? Is this possible?
Thank you in advance,
