I've seen it many times in 7.6.1.x too. The column expanding issue doesn't cause a problem, you can continue to edit and save the change. But for the element jumping issue, I had to reset the change, otherwise, it will break the layout.
I also saw another new issue with MAS 8.11, when creating a new single app, when adding a new column to the table header, everything disappeared. I had to edit the app in XML.
Viet Tran
https://relia.app------------------------------
Sent: 10-02-2024 10:33
Subject: Strange behavior in MAS Manage application designer
Has anyone else noticed some strange behavior in the Application Designer screen in MAS? Specifically, when you click on various elements, the overall vertical spacing increases, and each time you click the vertical spacing continues to increase?
Also, far more rarely, when you click one element it "jumps" to the top of a section...
Or am I the only one?
Jade Warren
Great River Energy
