ย View Only
Struggling with Bulk User Imports in MAS 9.1?
  • 1.  Struggling with Bulk User Imports in MAS 9.1?
    Posted 09-09-2025 09:25
    I put this post on IBM Tech Exchange but in dire need of answer asap so trying here as well. Sorry for Cross Posting:
    It looks like IBM has changed how bulk user imports work between MAS 9.0 and MAS 9.1-and not for the better.
    In MAS 9.0, there was a straightforward template we could use for user imports. But with MAS 9.1, that template no longer works. Instead, IBM now requires us to export existing data (using the MASPERUSER object structure) and then re-populate a sheet that mirrors that extract. The problem? There's little to no documentation on how this process is supposed to work.
    The old template had 42 columns, which was manageable. The new extract has 132 columns-and there's no clear guidance on which fields are actually required to successfully import users. To make matters worse, there are multiple columns for emails, multiple columns for status, and the overall structure feels messy.
    Even more concerning: I can't find any fields that handle Entitlements, App Point assignments, or related access settings. If those aren't included, that raises serious questions about how to properly configure new users in bulk.
    So my question to the community is this:
    ๐Ÿ‘‰ Has anyone successfully imported users in MAS 9.1 using this new process?
    ๐Ÿ‘‰ If so, which columns did you include, and how did you handle App Point / Entitlement assignments?
    Would really appreciate any insight or examples that could save others from hours of trial and error.
    #Security
    David Miller
