Hi Jason,
Thanks so much for the library.
I tried to apply the solution to MAS 9 but it failed with error:
[err] javax.crypto.BadPaddingException: Given final block not properly padded. Such issues can arise if a bad key is used during decryption.
I tried:
No issues with the build but it fails on the ui start :( Nothing helped.
Would much appreciate your help!
30 Sep 2024 04:21:48:240 [INFO ] [maximo] BMXAA6453I - The server is connecting to database version: V9000-127
[err] at java.base/com.sun.crypto.provider.CipherCore.unpad(CipherCore.java:1065)
[err] at java.base/com.sun.crypto.provider.CipherCore.fillOutputBuffer(CipherCore.java:1145)
[err] at java.base/com.sun.crypto.provider.CipherCore.doFinal(CipherCore.java:919)
[err] at java.base/com.sun.crypto.provider.AESCipher.engineDoFinal(AESCipher.java:446)
[err] at java.base/javax.crypto.Cipher.doFinal(Cipher.java:2202)
[err] at psdi.util.MXCipher.decData(MXCipher.java:293)
[err] at psdi.server.MXServer.getPkgFromJar(MXServer.java:2251)
[err] at psdi.server.MXServer.packagingCheck(MXServer.java:1867)
[err] at psdi.server.MXServer.boot(MXServer.java:1685)
[err] at psdi.server.MXServer.start(MXServer.java:3905)
[err] at psdi.servlet.MAXIMOStartupServlet.init(MAXIMOStartupServlet.java:116)
[err] at com.ibm.ws.webcontainer.servlet.ServletWrapper.init(ServletWrapper.java:301)
[err] at [internal classes]
[err] at com.ibm.ws.webcontainer.osgi.WebContainer.access$100(WebContainer.java:113)
[err] at com.ibm.ws.webcontainer.osgi.WebContainer$3.run(WebContainer.java:996)
[err] at java.base/java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:515)
[err] at java.base/java.util.concurrent.FutureTask.run(FutureTask.java:264)
[err] at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1128)
[err] at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:628)
[err] at java.base/java.lang.Thread.run(Thread.java:839)
30 Sep 2024 04:21:59:933 [FATAL] [maximo] BMXAA6473E - The MXSERVER server could not be started. Check the log file for other errors to determine the cause.
psdi.util.MXSystemException: BMXAA4072E - The formatting for the packaging file is incorrect. Contact IBM Support for help in removing the corrupt files. Then reinstall new files using the PkgInstall utility.
at psdi.server.MXServer.getPkgFromJar(MXServer.java:2255) ~[businessobjects.jar:?]
at psdi.server.MXServer.packagingCheck(MXServer.java:1867) ~[businessobjects.jar:?]
at psdi.server.MXServer.boot(MXServer.java:1685) ~[businessobjects.jar:?]
at psdi.server.MXServer.start(MXServer.java:3905) [businessobjects.jar:?]
at psdi.servlet.MAXIMOStartupServlet.init(MAXIMOStartupServlet.java:116) [maximoui.war:?]
at com.ibm.ws.webcontainer.servlet.ServletWrapper.init(ServletWrapper.java:301) [com.ibm.ws.webcontainer_1.1.88.jar:?]
at com.ibm.ws.webcontainer.osgi.WebContainer.access$100(WebContainer.java:113) [com.ibm.ws.webcontainer_1.1.88.jar:?]
at com.ibm.ws.webcontainer.osgi.WebContainer$3.run(WebContainer.java:996) [com.ibm.ws.webcontainer_1.1.88.jar:?]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:515) [?:?]
at java.util.concurrent.FutureTask.run(FutureTask.java:264) [?:?]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1128) [?:?]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:628) [?:?]
at java.lang.Thread.run(Thread.java:839) [?:?]
30 Sep 2024 04:21:59:938 [ERROR] [maximo] BMXAA6538E - Failed to initialize MAXIMO business object services.
at psdi.server.MXServer.start(MXServer.java:3905) ~[businessobjects.jar:?]
[ERROR ] SRVE0271E: Uncaught init() exception created by servlet [MAXIMOStartupServlet] in application [maximoui]: javax.servlet.ServletException: BMXAA6539E - Failed to initialize the MAXIMOStartupServlet with exception: BMXAA4072E - The formatting for the packaging file is incorrect. Contact IBM Support for help in removing the corrupt files. Then reinstall new files using the PkgInstall utility.
at psdi.servlet.MAXIMOStartupServlet.init(MAXIMOStartupServlet.java:129)
[ERROR ] SRVE0276E: Error while initializing Servlet [MAXIMOStartupServlet]: javax.servlet.ServletException: BMXAA6539E - Failed to initialize the MAXIMOStartupServlet with exception: BMXAA4072E - The formatting for the packaging file is incorrect. Contact IBM Support for help in removing the corrupt files. Then reinstall new files using the PkgInstall utility.
Oslc servlet.... Server did not started yet. Will wait 30 sec.
Alexey Potanin
Denver Technology
Sent: 04-07-2022 11:59
Subject: Zebra Label Printing from Maximo
We have published a solution for printing Zebra labels from Maximo. This has a full Maximo 7.6.1 / MAS 8 compatible installation and deploys in a few minutes. We also provided an uninstaller in case you want to pull it out.
Hopefully this is helpful to you all and if you have questions feel free to reach out.
GitHub - sharptree/zebra-printing-scripts| GitHub | remove preview |
| | GitHub - sharptree/zebra-printing-scripts | | The Zebra Label Printing automation scripts provide the ability to define uniquely identified printers and labels, and then print labels by providing the printer and label names as well as a object name and object unique identifier. | | View this on GitHub > |
Jason VenHuizen
Sharptree
