You shouldn't have multiline JDBC URLs. Have you looked at how to define the JDBC URL for Oracle to provide the arguments you want?
I haven't tried this but this states you can simply use what you have verbatim in your TNS names file in the JDBC URL (https://stackoverflow.com/questions/14194750/java-jdbc-how-to-connect-to-oracle-using-tnsnames-ora). So if you don't want to define it using JDBC syntax you might be able to do it like you would in the TNS names. But you wouldn't need multiple lines for this either (this is all on a single line).
Sent: 02-22-2022 05:17
Subject: How can we specify multiple lines for a given property in maximo.properties file.
I tried with "+" but got NL exception.
say for example for db URL i will specify property value as we define in tnsnames.ora file.
regards
syed mehdi
kng
