The answer is yes you can do this. You can attached an automation script to the save event on the work order object, then get the relationship to the work order spec child set, iterate over the set, find the 12 attributes you need for your calculation and then set your other 4.
If you have a more concrete example I can write an example script for you.
- Jason
Jason VenHuizen
Sharptree
Sent: 06-09-2022 13:24
Subject: Automation script to customize workorder specification
Is it possible to customize attributes of workorder specification with automation script?
We have 16 attributes attached to workorder specification, we want to perform some calculation based on 12 attribute and want to populate result in rest 4 attribute? How can we achieve this?
#Automationscript
#Analytics
#Architecture
#CivilInfrastructure
#HSE/OilandGas
#Infrastructure
#IoT
#LifeScience/Calibration
#Linear
#MaximoForAviation
#Nuclear
#Procurement
#Scheduling
#Security
#ServiceProvider
#Spatial
#Transportation
#Utilities
#WorkCenters
#Automationscript
