Using MAS 8.10.1 SNO version with Oracle Database
Created object structure above and started to test with SoapUI
Params:
Headers:
x-method-override: BULK
apikey: for user
Body (raw / text):
"_action":"Update",
"href":"os/m4m_locations_bulk/39",
"matusetrans":[
"_action":"Add",
"issuetype": "ISSUE",
"itemnum": "11406",
"description": "AC Spark Plug",
"location": "CENTRAL",
"binnum": "A-5-6",
"quantity": 1,
"actualdate": "2023-07-12T16:47:43",
"issueto": "WILSON",
"siteid": "BEDFORD",
"gldebitacct" : "6200-300-200",
"glcreditacct" : "6600-800-800",
"linetype" : "ITEM",
"issueunit" : "EACH",
When tested with MatUseTrans with that same data in Maximo UI and it worked fine.
Then added the gl accounts just in case, linetype and isseunit…still getting the same error "enter a valid item…".
Even tried specifying the ItemId and ItemSet in the body; same error.
Even with a simple OS, MX_MatUseTrans, with a simple post and it didn't work either:
"message": "BMXAA1870E - A material issue/return transaction cannot be added from here.",
Technically this should work in Maximo is there a bug in Maximo-REST?
#MaximoApplicationSuite------------------------------
Roger Vallee
Prometheus Group
