I guess another option that nobody suggested is that you could increase the length of the description field to the maximum allowable for that datatype..
which for Oracle would be 2000 characters.
then in the application designer change the description to a multi-line text box instead of just a text box.
Sent: 12-06-2023 11:11
Subject: Continuing Description field over to Long Description
Thank you all for your suggestions.
Stevie Holloway
Tufts University
Sent: 12-06-2023 10:04
How about this automation script solution?
(example for work log)
AUTOMATION SCRIPT
AUTOSCRIPT: WLDESC
DESCRIPTION: WORKLOG - Add description from long_description
LANG: python
code:
from psdi.mbo import MboSet
from psdi.util import HTML
worklog = mbo.getThisMboSet()
if(worklog is not None and worklog.getMboValueData("DESCRIPTION").isNull()):
descriptionLongDescription = HTML.toPlainText(worklog.getString("DESCRIPTION_LONGDESCRIPTION"))
description = descriptionLongDescription[0:99]
worklog.setValue("DESCRIPTION", description, MboConstants.NOACCESSCHECK)
LAUNCHPOINTNAME: WLDESC
OBJECT: WORKLOG
Event: Save , Add, Before Save
enter long text to long_description field and save SR.
Result
Jan Ondrušek
Sent: 12-04-2023 14:15
Is there a solution for continuing (spilling over ) a description field (+100 characters) over into the long description field, whether typed in or copied and pasted?<o:p></o:p>
Stevie Holloway
Tufts University
