Hi Everyone,
My team has created a custom Maximo application with POLINE as the Main Object. The goal is to show all the Purchase Order, Work Order and Invoice records side-by-side.
Even though I've been able to add table columns that successfully return these attributes by using the out-of-the-box relationships between the POLINE and the INVOICELINE tables, I have noticed that a PO with multiple invoices submitted against it will only display one invoice #. I'd like to show all the invoices submitted against each PO even if that means having multiple rows with the same PO #. Could anyone let me know if this is possible?
I am confident that the out of the box relationships I am using from the parent object, POLINE, with the child object, INVOICELINE, are correct because the relationship description states "Relationship to the InvoiceLine table, used to find all invoice line records for a given purchase order line."
I could build a new custom application with INVOICELINE as the main object. Since I want to show all the POs and WOs regardless if they have been invoiced against or not, I'd need to build a right outer join where clause that joins the INVOICELINE object with the POLINE object.
Any assistance would be greatly appreciated.
#MaximoApplicationSuite------------------------------
Carlos Mestre
Home Depot
