Create the new control xml and place it on the server (per the link I posted previously).
Modify the application's xml and import it.
It should work.
Sent: 02-14-2024 09:41
Subject: How to edit field length in App Designer?
Thanks "Sid",
We'll give it a try in our DEV environment.
By the way, after that customization do you need to change anything before you do a new build & deploy?
Regards
André Cordeiro
Sent: 02-14-2024 09:23
Yes, I have. Very recently as a matter of fact.
If we can figure out the logistics, we can get where I can show you the result, but I'll attach a screenshot as an example. You can see below that the 1st part of the multipart textbox is much larger than the second.
John "Sid" Ogden
Senior Functional Analyst
General Dynamics Information Technology
John.Ogden@gdit.com
334-260-3217 (Direct)
334-279-6145 (Fax)
Sent: 2/14/2024 8:49:00 AM
Subject: RE: How to edit field length in App Designer?
Hi Sid,
Do you have used this with the iot18 skin?
Regards
André Cordeiro
Sent: 02-13-2024 08:50
As stated by others, you cannot change the width of table columns nor either part of a multipart textbox from within Application Designer. However, you can edit the xml directly to modify table column width by adding 'width="nn" ' within the tag for the column. So, export the xml through App Designer, edit it and reimport it through App Designer. Not a direct answer, but a work around.
This leaves multipart textboxes as an issue. The following link provides a method by which you can create your own 'zzmultiparttextbox' control. This requires an ear build to become usable, but then provides a way to independently size each part of a multipart textbox in a way similar to the work around above.
https://www.linkedin.com/pulse/dynamic-width-fields-multiparttextbox-faisal-sayeedi
I have used the information in the link above successfully in about 10 projects to date.
Sid Ogden
GDIT
Sent: 02-08-2024 10:56
Hello More Maximo Community,
Is there a way in App Designer to edit the length of fields so that I can make them even?
Thank you in advance,
