Alex's recommendation is certainly the easiest way to invoke a script from outside Maximo, but it also has no security constraints so any valid Maximo user, no matter what their privilege level will be able to invoke your script.
Alternatively, you can attach an action to an object structure, which then requires access to the object structure to invoke the actions, so there is at least some restriction. The process is discussed in this IBM thread, but it does require a bit more work both in set up and invoke.
Create actions to invoke on an object structure | Maximo (ibm.com)Another option is to bake in security into your script. I wrote a post on this a while back, which you can check out here.
Sharptree | Blog | Implementing security restrictions using Automation ScriptsThe post describes how to check that the user has a particular sigoption before executing the script.
Jason VenHuizen
Sharptree
Sent: 06-08-2022 10:39
Subject: Lasunch Automation Script from another outside application
HI All,
Does anyone know the proper way or method to call/launch a Maximo Automation script from outside of Maximo.
Brian Swanson
Herman Miller
