I would recommend you to check the status handler class and custom mbo class and the following methods in it
public void changeStatus(String currentStatus, String desiredStatus, Date date, String memo)--- In handler
public void changeStatus(String status, Date date, String memo)---In your custom mbo class
Nidhil Chathoth
ECCS Ltd
Sent: 07-28-2023 11:33
Subject: To create Change Status Action for custom application
Hi Subhransu,
I'm actually not getting any error while am trying to perform change status action. However the values are not getting saved in my main object -status field but the dailog box is working fine.
Roja
Roja P
Sent: 07-28-2023 01:05
Hi Roja,
What error you are getting while trying to change the Status in the dialog box?
Subhransu
Subhransu Sekhar Sahoo
PriceWaterHouseCoopers Services Pvt Ltd
Sent: 07-27-2023 04:38
Needed some guidance on implementing simple change status action, for the custom application which is created using custom object.
I am new to this java customization and tried following below procedure got stuck.
- created 3 objects: 1st one main object, 2nd persistence object and 3rd one non-persistence object.
- Created Synonym domain from backend and attached in the status fields of all the 3 objects .
- In the main object class path: Created class file which extends statefulmbo and provided set class path which extends mboset , not override any methods
- In the 2nd persistence object : Created a class file which extends mbo and provided set class path which extends mboset
- In the 3rd non-persistence object: created a class file which extends changestatus and provided set class path which extends ChangeStatusSet
- created one dialog box and used common bean class and displayed all the fields of 3rd non-persistence object using relationship
By following all these still status is not getting changed.
Please advice on the same.
Roja
#MaximoForAviation
Roja P
