1. Copy the INPUTWF dialogue from the LIBRARY.xml to your app XML.
2. Create a Condition with:
( :ACTIONID in (select distinct ACTIONID from WFACTION where PROCESSNAME = [YOUR PROCESS] and PROCESSREV= (select processrev from wfprocess where active = 1 and processname = [YOUR PROCESS]) ))
* You may need to change the query if your INPUT is in a Sub-process.
3. Create Global Data Restriction - Attribute Restriction
Object: WFINPUT
Attribute: MEMO
Application: YOUR APPLICATION
Type: REQUIRED
Reevaluate: Y
Condition: YOUR CONDITION
Maycon Belfort
BPD Zenith
Sent: 09-01-2023 00:16
Subject: Work Flow Manual Input node Mandatory Memo
How to set Memo in Manual input node mandatory using data restriction is not working any suggestion
#Analytics
#Architecture
#CivilInfrastructure
#HSE/OilandGas
#Infrastructure
#IoT
#LifeScience/Calibration
#Linear
#MaximoForAviation
#Nuclear
#Procurement
#Scheduling
#Security
#ServiceProvider
#Spatial
#Transportation
#Utilities
#WorkCenters
Fathi Deghadi
Consolidate Contractor Company
