An update: The maxinst log file has the error listed below. 8000_02.dbc does exist, and it's in the correct place in the customization archive zip file. It's in the same location as 8000_01.dbc, in the initial archive that worked.
9928Product: My Customization updatedb process starts ...
99290 ms SET XACT_ABORT OFF
9930;
9931// Success.
9932MYCUSTOMIZATION: V8000-1, Current release DB build: V8000-11, Last release DB build: V8000-00
9933Database script update in progress, please wait..........
9934Current version :V8000-1
9935Updating To :V8000-11
99361 ms SET XACT_ABORT OFF
9937;
9938// Success.
9939Script Update complete: Error
9940java.lang.Exception: Script class or text file for V8000_02 does not exist. Please contact system administrator.
9941at psdi.tools.RunScripts.run(RunScripts.java:125)
9942
Jose Nodeland
JedaWorks
Sent: 05-05-2024 10:20
Subject: MAS customization archive
I've added a customization archive to MAS, everything worked (I think, not sure if the class files were added.. if anyone knows of an easy way to see the class files, please share that info) I can see the database changes that are outlined in the dbc file, and the maxvars variable indicates the archive was processed successfully.
I'm now adding an additional customization archive that builds on the first archive, but it's never processed.
The customer.xml for the first archive is below. After processing, the maxvars variable MYCUSTOMIZATION has the value "V8000-01".
<?xml version="1.0" encoding="UTF-8" ?>
<product xmlns="http://www.ibm.com/maximo/product.xml">
<name>My Customization</name>
<version>
<major>8</major>
<minor>0</minor>
<modlevel>0</modlevel>
<patch>0</patch>
<build>20710413-0001</build>
</version>
<dbmaxvarname>MYCUSTOMIZATION</dbmaxvarname>
<dbscripts>customization</dbscripts>
<dbversion>V8000-01</dbversion>
<lastdbversion>V8000-00</lastdbversion>
<extensions>
</extensions>
</product>
The customer.xml for the second archive is below. This one is never processed. The dbc files V8000-02 to V8000-10 are in the customization archive zip file. Can anyone see what I am doing wrong, and why this second archive is being ignored?
<version>
<major>8</major>
<minor>0</minor>
<patch>0</patch>
<build>20710413-0002</build>
</version>
<dbversion>V8000-10</dbversion>
<lastdbversion>V8000-01</lastdbversion>
<extensions>
</extensions>
</product>
Jose Nodeland
JedaWorks
