Hello All,
Need some guidance on the code bolder below as we are trying to convert the poline to a number format but when we try to complete the receiving of a line,system is giving an error related to conversion from string to number,we want to take the substring of the poline from position 2 until 4 characters and convert that to a number format as the Oracle system is havign this field defined as number data type.
Below is the line that is getting failed
and a.segment1 = '"""+ponum+"' and c.line_num = to_number(substr('"+poline+"'"+",2,4))")
from teu.iface.common import TEUJDBCUtils
from teu.iface.common import TEUEndPointUtils
from java.sql import Connection;
def setError(linenum):
global errorkey, errorgroup, params
errorkey="LineClosedInOracle"
errorgroup="TEURECEIPTS"
params=[linenum]
mxserver = MXServer.getMXServer()
ponum = mbo.getString("PONUM")
poline = mbo.getString("POLINENUM")
SUBSTRING = mbo.getString("POLINENUM")
poline=(SUBSTRING[3:-10])
linenum=int(poline)
raise TypeError (linenum)
conn = None
myEndPoint = TEUEndPointUtils()
myjdbcUtil = TEUJDBCUtils()
#endPoint= myEndPoint.getEndPoint("TEUORARAC")
endPoint = "TEUORACLEENDPOINT"
#added below check to avoid the error in WO Application
if (mbo.getThisMboSet().getParentApp()=='RECEIPTS'):
if (endPoint is not None or endPoint == ""):
myEndPoint.getEndPointinfo(endPoint);
if myEndPoint is not None:
conn = myjdbcUtil.getConnection(myEndPoint)
if conn is not None:
if (mbo.toBeSaved() and mbo.getString("ISSUETYPE") == "RECEIPT" ):
s= conn.createStatement()
rs=s.executeQuery("""select a.po_header_id,c.PO_LINE_ID, a.segment1 as PONUM, c.line_num as POLINENUM, a.org_id, a.closed_code as POSTATUS, b.shipment_num as SHIPMENT_NUM, b.closed_code LINE_STATUS
from po_headers_all a,po_line_locations_all b, PO_LINES_ALL c
where a.po_header_id = b.po_header_id
and a.po_header_id = c.po_header_id
and b.po_line_id = c.PO_LINE_ID
and b.closed_code in ('CLOSED','CLOSED FOR RECEIVING')
if rs.next():
setError(poline)
rs.close()
s.close()
conn.close()
#Administration#Customizations#EverythingMaximo#HSE/OilandGas------------------------------
Mahadevan Ramakrishnan
