Hello all,
Following is a script that I developed to fetch the a certain records using SQL and then I want to read record by record to the end of result set "RS". I have a problem that I do not get any error but there is no impact of the process as the script does not do any modification.
NOTE: When I use " while rs is not None:" instead of ""while (rs.next())" then
it seems it is get into the loop but then I've an error at "mTSDAY = str(rs.getDate(TS_DAY))"
Any hep much appreciated.
from java.util.concurrent import TimeUnit
from java.lang import Math
from java.text import SimpleDateFormat
from psdi.security import ConnectionKey
from java.sql import Connection
from java.sql import Statement
mTS = MXServer.getMXServer().getMboSet("ZZAMSTIMECARD", mbo.getUserInfo())
mBIO = MXServer.getMXServer().getMboSet("ZZICLOCK", mbo.getUserInfo())
connKey = mbo.getThisMboSet().getUserInfo().getConnectionKey()
conn = mbo.getThisMboSet().getMboServer().getDBConnection(connKey)
sql = "SELECT DISTINCT FINGERNO, TS_DAY, TS_YEAR, TS_MONTH, PUNCH_IN, PUNCH_OUT, TSDAY_CHAR FROM (SELECT A.EMP_CODE FINGERNO, TRUNC(A.PUNCH_TIME) TS_DAY, EXTRACT(YEAR FROM PUNCH_TIME) TS_YEAR, EXTRACT(MONTH FROM PUNCH_TIME) TS_MONTH, SUBSTR(TO_CHAR ((SELECT MIN(PUNCH_TIME) FROM ZZICLOCK B WHERE A.EMP_CODE=B.EMP_CODE AND TRUNC(A.PUNCH_TIME)=TRUNC(B.PUNCH_TIME)),'DD/MM/YYYY HH24:MI:SS'),12,5) PUNCH_IN, SUBSTR(TO_CHAR ((SELECT MAX(PUNCH_TIME) FROM ZZICLOCK B WHERE A.EMP_CODE=B.EMP_CODE AND TRUNC(A.PUNCH_TIME)=TRUNC(B.PUNCH_TIME)),'DD/MM/YYYY HH24:MI:SS'),12,5) PUNCH_OUT,SUBSTR(TO_CHAR ((SELECT MAX(PUNCH_TIME) FROM ZZICLOCK B WHERE A.EMP_CODE=B.EMP_CODE AND TRUNC(A.PUNCH_TIME)=TRUNC(B.PUNCH_TIME)),'DD/MM/YYYY HH24:MI:SS'),1,10) TSDAY_CHAR FROM ZZICLOCK A where trunc(a.punch_time)>=(select max(TRUNC(ts_day)) from zzamstimecard)) order by FINGERNO, ts_day"
s = conn.createStatement()
rs = s.executeQuery(sql)
conn.commit()
while (rs.next()):
mTSDAY = str(rs.getDate("TS_DAY"))
#mTS.setWhere("TS_DAY=:rs.ts_day and FINGERNO=:rs.fingerno")
mTSS = mTS.getMboSet("$NewWO","ZZAMSTIMECARD","FINGERNO='" + rs.getString("FINGERNO") + "'");
if mTS.isEmpty():
mTIMESHEET = mTS.add()
mTIMESHEET.setValue("TS_DAY",rs.getDate("TS_DAY"))
mTIMESHEET.setValue("FINGERNO",rs.getString("FINGERNO"))
mTIMESHEET.setValue("PUNCH_IN",rs.getString("PUNCH_IN"))
mTIMESHEET.setValue("PUNCH_OUT",rs.getString("PUNCH_OUT"))
else:
mTS.setValue("PUNCH_IN",rs.getString("PUNCH_IN"))
mTS.setValue("PUNCH_OUT",rs.getString("PUNCH_OUT"))
mTIMESHEET = mTS.save()
Mohammad Moula
eSolution
