  • 1.  WHERE USED - INVENTORY REPORT
    Posted 11-10-2023 11:54
    Hello all, thank you for all of the previous help.
    Is it possible to pull the "Where Used" information from Inventory?
    I can't find any out-of-the-box options, would I have to update the object structures and database config? or perhaps use a SQL tool?
    Thank you for any ideas
  • 2.  RE: WHERE USED - INVENTORY REPORT
    Posted 11-13-2023 08:49
    A SQL Tool is likely easier, as it is a single object involved: SPAREPART. This provides the data you see in the where used section of the inventory application as well as the spare part section of the asset application.
    select * from sparepart
  • 3.  RE: WHERE USED - INVENTORY REPORT
    Posted 11-17-2023 17:38
    Thank you @Christopher Winston,  I got connected to the database with an SQL tool today and was able to run this.
