 Unable to route workflow
  • Work Management
Trisha S's profile image
Trisha S posted 03-12-2026 12:18
User is trying to route to schedule status but getting error BMXAA4407E A nested exception caused the workflow process to fail
BMXAA8229W Record Woactivity has been updated by another user.
Can anyone tell me how to resolve this?
Allan Henle's profile image
Allan Henle
Hi Trisha,
As the error suggests the woactivity record is being 'updated by another user.' That user could be a physical user who is also on the record making change to the WO. It could also be something that is updating the record as part of the Workflow that it is getting tripped up on. Finally, it could be getting updated by automated processes like automation scripts, escalations, and cron tasks. You may need to look at a few different things. If you get the error, you might try refreshing your record and trying to run the workflow again.
Without knowing your system and your workflow it is hard to tell.
Trisha S
Hi Allan,
Thanks for answering . If I ask to stop the workflow and then re route it again,would that be an issue? Can you please help me .Also,Can you tell me how do i check if any other process is throwing this error? Script, workflow etc
Danielle Shaw's profile image
Danielle Shaw
Trisha,
This error is infamously vague. Do you have any automation scripts that run on WO (or WO activity) status change? Or that occur on save of a WO?
What other actions does the workflow node that changes the status do?
