 Child table update does not trigger launch point for main object
Jump to  Best Answer
Eric Godel's profile image
Eric Godel posted 07-15-2022 11:56
I have an automation script with the launch point SAVE, ADD, UPDATE, BEFORE SAVE of WORKORDER object.
When I make a change to any child table related to my work order and only the child tables, the launch point is not triggered.  Its only if I have an update on the WORKORDER table itself that will trigger this launch point to run.  This seems the same for custom objects or out of box objects.
Its deceiving because when I have modified my related tables, the save button for my work order opens up, making it seem like it will save the WORKORDER object, and not just the related tables.
What am I missing here?  Is there a UI trick I should be doing?  Should I just be moving my launch point to my related tables?
Thanks in advance!
Eric
Craig Kokay's profile image
Craig Kokay  Best Answer
Hi Eric,
When you update a child is added or updated, it does not cause the parent to be updated i.e. a change to the rowstamp.  So you can't have a generalised script.  So, yes you're fooled by the save icon.
You can have a script cause a change on the parent to then fire off the other script, but be careful that you are not causing a loop.
Eric Godel
Craig, thank you for your answer.  This is actually what I did while waiting for this confirmation, no infinite loops this time though :)
kenta nakao's profile image
kenta nakao
Perhaps the link is helpful.
https://www.ibm.com/support/pages/marking-main-record-modified-while-modifying-related-child-records-automation-scripts-v76
