I keep hitting a network time out and get this in the log, wondering what's not set correctly???
2021-10-13 12:22:34 [INFO] Error message dialog
2021-10-13 12:22:34 [DEBUG] Error code : -2147012894 (2147954402)
2021-10-13 12:22:34 [DEBUG] Error source : msxml6.dll
2021-10-13 12:22:34 [DEBUG] Error description : The operation timed out
2021-10-13 12:22:34 [DEBUG] Remedy : Network timeout. Check timeout settings in Config sheet.
These are the config settings
| Advanced |
| Maximum Objects |
30000 |
| Batch Size |
0 |
| Split Child Rows |
FALSE |
| Start Row |
3 |
| Stop On Error |
TRUE |
| Continue Sync |
TRUE |
| Display Query Warning |
TRUE |
| Display Summary |
TRUE |
| Query Only |
FALSE |
| Store Passwords |
TRUE |
| Formatting |
| Timezone |
0 |
| DateTime Format |
yyyy-mm-dd hh:mm |
| Date Format |
yyyy-mm-dd |
| Time Format |
hh:mm |
| Logging |
| Logging |
Trace |
| Log File Name |
[XLSDIR]\[XLSNAME].log |
| Advanced Connection Settings |
| Proxy |
| Proxy User |
| Proxy Password |
| Resolve Timeout |
10 |
| Connect Timeout |
20 |
| Send Timeout |
30 |
| Receive Timeout |
600 |
| OS Service Context Root |
/meaweb/os/ |
| OSLC Service Context Root |
/maximo/oslc/ |
| API Service Context Root |
/maximo/api/ |
| XML Namespace |
http://www.ibm.com/maximo |
Paul Crocker
BPU
