I'm having the same problem. It looks as though MxLoader is converting 'some' of the data into SQL date format. The debug file is showing where the filed has been set to DATETIME:
2022-06-09 11:13:59 [INFO] Sheet name : Work Order
2022-06-09 11:13:59 [INFO] Object service : MXAPIWO
2022-06-09 11:13:59 [INFO] Object name : WORKORDER
2022-06-09 11:13:59 [INFO] Action : AddChange
2022-06-09 11:13:59 [INFO] Where :
2022-06-09 11:13:59 [DEBUG] Order By :
2022-06-09 11:13:59 [DEBUG] OSLC Directives :
2022-06-09 11:14:00 [DEBUG] Attr(1) : WONUM ()
2022-06-09 11:14:00 [DEBUG] Attr(2) : SITEID ()
2022-06-09 11:14:00 [DEBUG] Attr(3) : STATUS ()
2022-06-09 11:14:00 [DEBUG] Attr(6) : LEAD ()
2022-06-09 11:14:00 [DEBUG] Attr(7) : ACTSTART (
DATETIME)
2022-06-09 11:14:00 [DEBUG] Attr(8) : ACTTEMPFIX ()
2022-06-09 11:14:00 [DEBUG] Attr(9) : ACTFINISH (
DATETIME)
So ACTSTART and ACTFINISH are being converted correctly but ACTTEMPFIX is taking the Excel date:
<ACTSTART>2022-06-08T14:10:00</ACTSTART>
<ACTTEMPFIX>44720.6041666667</ACTTEMPFIX>
Is there some way to tell MxLoader to convert the field to DATETIME? e.g. ACTTEMPFIX (DATETIME)
Ian Turner
Mitie
Sent: 03-10-2022 09:52
Subject: Upload Format Date/Time
Hi Abdelrahman,
I just queried a workorder with SCHEDSTART and received the following format: YYYY-MM-DD HH:MM
I changed the SCHEDFINISH and loaded into Maximo and it took successfully.
Please let me know if that works.
Matt McGuire
Aquitas Solutions
Sent: 03-08-2022 06:51
Hi Matt,
Thank you reply me,
I tried add values in (SCHEDSTART,SCHEDFINISH,ACTSTART,ACTFINISH,HANDOVERDATE and CLOSEDDATE) fields at WORKORDER application.
I used format date mm/dd/yy and yyyy-dd-mmThh:mm:ss:mm, But Still are not valid
Any idea solve of the problem?
thanks
Abdelrahman Elwakeel
smartsystemeg.com
Sent: 03-01-2022 09:22
Hi Abdelrahman,
What is the field you're trying to populate?
The easiest way to determine what format the date field needs is by querying a record. Some fields can take mm/dd/yy others take yyyy-dd-mmThh:mm:ss:mm
Matt McGuire
Aquitas Solutions
Sent: 02-09-2022 03:51
I have some problem about Date/Time format I have used upload data from master Microsoft Access Database to Maximo App.
But What is correct Date/Time format in Maximo DB? Any one help me?
smartsystemeg.com
