  • 1.  Automation Script transform outbound data
    Posted 12-06-2021 10:54
    Is there a way to leverage the automation script to transform outbound data.  API is setup with a request directly to an Object structure and one of the columns is in all caps that need to be all lower case.
    Thanks.
    Kirk Youngbauer
    Great River Energy
  • 2.  RE: Automation Script transform outbound data
    Posted 12-07-2021 10:45
    There is a whole Automation Script pipeline that basically maps to the old Processing and User Exit classes.
    Here are the docs on it:
    https://www.ibm.com/docs/en/mamss?topic=scripts-customization-object-structure-processing
    If you have specific questions let me know, I'd be happy to help.
    Jason
    Jason VenHuizen
    Sharptree
  • 3.  RE: Automation Script transform outbound data
    Posted 12-07-2021 10:48
    Look at utilizing the overrideValues on the object structure (https://www.ibm.com/docs/en/mam/7.6.1.2?topic=structures-set-values-in-fields ). In the automation script application you create a launch point for integration, pick the object structure, and then say it's for outbound definition. Let me know if you have issues but especially for a simple transformation like this it should just work.
