Vincente,
It looks like syntax.
((woclass = 'WORKORDER' or woclass = 'ACTIVITY') and upper(reportedby) like :USER and historyflag = 0 and istask = 0)
seems to translate well. The ' and % are not normally needed, so the only real issue is having the user and person codes to be the same.
The executed query becomes:
((woclass = 'WORKORDER' or woclass = 'ACTIVITY') and upper(reportedby) like 'MAXADMIN' and historyflag = 0 and istask = 0)
if you run as MAXADMIN, as an example.
The general rule when using substitution variable for user would be:
related to the current user being the person assigned as lead (replace 'lead' below with reportedby, supervisor, owner, etc., as needed)
…lead = (select personid from person where personid = (select personid from maxuser where userid = :USER ))
This will handle situations when the user id and person id are different.
Sent: 12-30-2021 11:12
Subject: Start Center portlet , data disappeared
here is the query , the query no longer will pull information , is there something missing on this or how do make another one
the portlet allows the end user to see what has been issued to him or her , this portlet is on the template that is used company wide.
((woclass = 'WORKORDER' or woclass = 'ACTIVITY') and upper(reportedby) like '%:&USER&%' and historyflag = 0 and istask = 0)
#HSE/OilandGas
Vincente Orosco
