Hi Ashok,
I believe the PM application simply shares the same worktype domain you build from organizations -> work order options -> work types. That being said, in Condition monitoring, you can set up your monitoring point to create a work order from a PM rather than a job plan. If you were creating a corrective or emergency work order from a meter reading being monitored in condition monitoring, the PM you choose to create the work order having those work types would be the best reason I could think of.
Welcome to hear anyone else ideas on this.
thanks!
Eric Godel
Eric Godel
Bay Systems Consulting
Sent: 10-06-2022 12:16
Subject: PM Work Type
In Maximo's PM application I noticed inclusion of work types 'CM' and 'EM'. I understand these are expected to be used on meters based PM's (not on time-based PM) but can anyone in this forum give me some practical examples where the preventive maintenance work order generates a corrective or emergency type work order.
Thanks in advance
#Scheduling
Ashok Fernandes
EMA, INC
