MXLOADER 8.2
Maximo version 7.6.1.2
IBM WebSphere Application Server 9.0.0.7Server OS Linux
I am trying to connect ti Maximo from MXloader with server address as
http://[localhost]/but I am getting error
Not Found
Error 404: java.io.FileNotFoundException: SRVE0190E: File not found: /meaweb/os/MXASSET
Debugging I did:
1. Tried checking through URL from the browser, getting the same error.
http://[localhost]/meaweb/os/MXASSET 2. when trying to connect from test environment, successully able to connect.
3. checked for the system property - mxe.int.enableosauth and it is set to Zero.
Can anyone please assist on how to fix the issue?
#Integrations#Security------------------------------
Sharmeya Rajavel
Bahwan Cybertek
