Automation Script to Insert values in multiple rows
  • 1.  Automation Script to Insert values in multiple rows
    Posted 3 days ago
    Hope you all are doing great in these hard times.
    I have a requirement to insert a edited date value into a field on passing through a particular task node.
    To achieve this, I have written a Action Launch point automation script and defined it in the workflow. It was working fine to this point. 'code' is the name of the variable defined.
    from java.util import Date
    from java.text import SimpleDateFormat
    from psdi.mbo import Mbo
    cal= Calendar.getInstance()
    datetime=SimpleDateFormat().format(Date())
    date=datetime.split(' ')[0]
    time=datetime.split(' ')[1]
    month=date.split('/')[0]
    day=date.split('/')[1]
    year=date.split('/')[2]
    hour=time.split(':')[0]
    min=time.split(':')[1]
    code='20'+year+'-'+month+'-'+day+'-'+hour+''+min	​
    Sometimes there's gonna be multiple rows in which the value has to be inserted into multiple rows. I was trying to modify the script with While condition but it seems not working for me. The following is the script I was trying
    req=mbo.getMboSet("REQCONITEM")
    i=0
    records=req.getMbo(i)
    while(records is not None):
        i=i+1
        records=req.getMbo(i)​
    'REQCONITEM' is the name of the relationship
    Any help on this one is appreciated.
    Harshavardhan Kamepalli
    Eidiko System Integrators
  • 2.  RE: Automation Script to Insert values in multiple rows
    Posted 2 days ago
    You can use the moveFirst/moveNext methods in while loop. Or you can use 'for' loop as well.
    ###################################Using While Loop################################
    min=time.split(':')[1]​
    records=req.moveFirst()
      records = req.moveNext()
    ###################################Using For Loop################################
    records=req.count()
    for i in range(0,records):
      rowLevelMboRecords = req.getMbo(i)
    Venkatrao Y
    TCS
  • 3.  RE: Automation Script to Insert values in multiple rows
    Maximo Certified
    Posted 2 days ago
    Hi Harshavardhan,
    How do you know the script is not working? Also, How are you using the code variable?
    Your loop or single record is just setting the local variabel code but how are you using the code variable to know if it is working?
    I would try to print the req mboset count in logs or in a variable to check if the relationship is working.
    If the count is coming up as correct then please share the whole code.
    Biplab Choudhury
    Tata Consultancy Services
  • 4.  RE: Automation Script to Insert values in multiple rows
    Solution Provider
    Posted 2 days ago
    You might also try
    #iterable
    from com.ibm.tivoli.maximo.util.mbo import IterableMboSet
    for myMbo in IterableMboSet(myMboSet)
    I couldn't tell you the relative differences between either solution (perhaps some simplification)...
    keith simmons
    Aquitas Solutions
