Dear all,
That's my first topic on your great Maximo's community :)
I tried to create a new web service based on MXINVOICE object structure, to be called by Talend ETL middleware through SOAP protocol.
But when I try the connection, this following message occurs (even if i try to use MXLoader for example, it worked well before creating the web service)
Internal Server Error
Error 500: nested exception is: psdi.util.MXAccessException: BMXAA0031E - The INVOICE object is read only. Verify the business rules for the MBO or MBOSET object.
I made exctly the same with MXPO object structure and it works well.
Any idea to fix my web service based on MXINVOICE ?
Maximo's version : 7.6.1Thank you :)
Benoit
#Integrations------------------------------
Benoit Levasseur
Brittany Ferries
