  • 1.  Maximo Application Suite Playbook continues to be updated - a more than worthy bookmark
    Posted 01-05-2022 23:35
    The latest addition to the Maximo Application Suite page in this community is at https://moremaximo.com/browse/ibm-maximo-application-suite
    That addition is for the Playbook for Maximo EAM Upgrade. If you have not bookmarked it, do so now. We will continue to update the page in this community, but consider this 'playbook' page a key reference in your upgrade.
    #Architecture
    #Infrastructure
    #Functional
  • 2.  RE: Maximo Application Suite Playbook continues to be updated - a more than worthy bookmark
    Posted 01-06-2022 08:50
    Hi Christoper,
    I appreciate the playbook getting updated, it must be challenging though keeping up with the new versions of MAS as most of the links point to old versions of MAS.
    ISW
    Maximo Practice Manager
    eMail: ckokay@isw.net.au
    Phone: +61-411-682-040
    #IBMChampion2021
  • 3.  RE: Maximo Application Suite Playbook continues to be updated - a more than worthy bookmark
    Posted 01-06-2022 10:54
    Craig,
    Thanks for the reminder, and keep them coming. IBM has been kind enough to set a standard on the documentation landing page, nad they have continued to follow it. We will get that posted as well.
  • 4.  RE: Maximo Application Suite Playbook continues to be updated - a more than worthy bookmark
    Posted 01-07-2022 15:04
    Kudos again to IBM. As Application Suite continues to be updated, the documentation does as well, AND, the pages are following a format of https://www.ibm.com/docs/en/mas8X (and hopefully, linked in does not change the link so you can see the format):
    Maximo Application Suite Documentation Landing pages:
    Maximo Application Suite 8.6:    https://www.ibm.com/docs/en/mas86
    Maximo Application Suite 8.5:    https://www.ibm.com/docs/en/mas85
    Maximo Application Suite 8.4:    https://www.ibm.com/docs/en/mas84
    Maximo Application Suite 8.3:    https://www.ibm.com/docs/en/mas83
    Maximo Application Suite 8.2:    https://www.ibm.com/docs/en/mas82
    Maximo Application Suite 8.1:    https://www.ibm.com/docs/en/mas81
    Maximo Application Suite 8.0:    https://www.ibm.com/docs/en/mas80
    So, it is a good guess that 8.7 will be at https://www.ibm.com/docs/en/mas87, but that is just a guess.
    We will continue to update the Application Suite page here in the MORE community with this info, in case you lose this post, you should probably bookmark https://moremaximo.com/browse/ibm-maximo-application-suite
