  • 1.  RESULT SET PORTLET IS BLANK WITHOUT CHART
    Posted 03-24-2024 13:49
    I create 4 result set portlet based on a query on wotrack application.
    But when i login in my workcenter, i can't see the chart. I see the other informations but not a chart. I must reset it manually one by one result set portlet.
    I need helpl
    FULGENCE KOFFI
    SOPROV
  • 2.  RE: RESULT SET PORTLET IS BLANK WITHOUT CHART
    Posted 27 days ago
    Hi @FULGENCE KOFFI !
    I need more information to know how I can help you.
    If you give me a step by step to reproduce what you did, I can see what my result is to try to help you.
  • 3.  RE: RESULT SET PORTLET IS BLANK WITHOUT CHART
    Posted 26 days ago
    Hi Fulgence,
    I have inferred from your comments that you want the chart to show by default on the start center rather than just be available as an alternative to the list.
    Question 1: Did you set the result set chart to be the default option?
    Principal Consultant
    COSOL
    #IBMChampion
