  • 1.  How to have required default data in all work order
    Posted 05-10-2022 13:01
    Hi everyone,
       I want to have default data in long description  for all work-order created by the user (excluding the PM generated Workorders) Is it possible in MAXIMO.
    Divakar Mani
    Qaiwan Group
  • 2.  RE: How to have required default data in all work order
    Posted 05-10-2022 21:05
    Have you thought about using an automation script?  The question is when do you need it to fire.
    ISW
    Maximo Practice Manager
    eMail: ckokay@isw.net.au
    Phone: +61-411-682-040
    #IBMChampion2022
  • 3.  RE: How to have required default data in all work order
    Posted 05-11-2022 10:29
    What is the value in storing the same data multiple times? Defaults can make sense (setting a default insert site, setting a user's default storeroom, etc.) but storing a string of text over and over increases the size of the database without providing value. It'd be better to store this somewhere and display it via a relationship rather than duplicate it in the long description.
    If defaulting is required, you could create a script called WORKORDER.NEW and that would default when a record is added immediately (so a user could change it if necessary before saving).
    To check if a PM is generating, you need to import MXServer (from psdi.server import MXServer) and add a check like
    if MXServer.getBulletinBoard().isPosted("PM.GeneratingWork")
