  • 1.  MXINVOICE
    Posted 04-18-2022 13:18
    I am attempting to use the MxLoader to update the GLdebitacct for a number of invoices. The Loader Result is a green OK, but nothing is changed, I have tried add/change and change. Anyone have any pointers? The MXPO allows the change, but no luck with MXRECEIPT and MXINVOICE.
    -W
    Wes Williams
    Northrop Grumman
  • 2.  RE: MXINVOICE
    Posted 04-20-2022 08:30
    Hi Wes,
    Can you attach your MxLoader sheet? Just need the two header lines as no data is necessary.
    Adam
    Adam Ames
    Kwik Trip, Inc.
  • 3.  RE: MXINVOICE
    Posted 04-20-2022 10:38
    Well just an update, ..updates occur to INVOICE etc. if I leave the INVOICECOST. columns empty, unfortunately I want to update the GLDEBITACCT in the invoicecost table.
    MX_INVOICE
    Wes Williams
    Northrop Grumman
  • 4.  RE: MXINVOICE
    Posted 04-21-2022 07:44
      |   view attached
    Adam,
    I recreated as I have tried so many iterations. I run the query and it pulls data from all the tables except INVOICECOST. All I need to do is update the GLDEBITACCT on existing invoices as well as PO's (works) and receipts.
    Wes Williams
    Northrop Grumman
    Attachment(s)
    xlsm
    MxLoaderInvoice.xlsm   740 KB 1 version
  • 5.  RE: MXINVOICE
    Posted 04-21-2022 08:22
      |   view attached
    Hi Wes,
    I moved the invoice line columns ahead of the invoice cost columns and it worked as expected. I attached my very abbreviated template. I did the same with your template and it worked too. Let me know if you have any issues.
    Adam
    Adam Ames
    Kwik Trip, Inc.
    Attachment(s)
  • 6.  RE: MXINVOICE
    Posted 04-21-2022 10:30
    Thanks Adam!
    I got it working! Any pointer on receipts? I also need to update the GLDEBITACCT there.
    -Wes
    Wes Williams
    Northrop Grumman
  • 7.  RE: MXINVOICE
    Posted 04-21-2022 13:32
    I have receipts working as well
    Wes Williams
    Northrop Grumman
  • 8.  RE: MXINVOICE
    Posted 04-21-2022 15:09
    Hi Wes,
    Great to hear!!!
    Adam Ames
    Kwik Trip, Inc.
