  • 1.  Using MxLoader to Load Assets on Job Plans > Work Assets Tab
    Posted 02-18-2022 13:21
    Is it possible to use MxLoader to load multiple assets on the Job Plans > Work Assets tab?
    Stevie Holloway
    Tufts University
  • 2.  RE: Using MxLoader to Load Assets on Job Plans > Work Assets Tab
    Posted 02-21-2022 11:02
    Hi Stevie,
    Try adding the JPASSETSPLINK object to the MXL_JOBPLAN object structure. Then add the child object/attributes at the end of your load sheet. You must include JPASSETSPLINK ORGID and SITEID or the load will error out
    Matt McGuire
    Aquitas Solutions
  • 3.  RE: Using MxLoader to Load Assets on Job Plans > Work Assets Tab
    Posted 02-22-2022 10:35
    Hi Matt,
    I attempted your example by adding 2 lines with different ASSETNUMs but it only loaded one record.
    Stevie
    Stevie Holloway
    Tufts University
  • 4.  RE: Using MxLoader to Load Assets on Job Plans > Work Assets Tab
    Posted 02-22-2022 10:44
    Hey Stevie,
    Are you using "Add" or "AddChange"?
    I just tested and loaded two assets to my job plan:
    Can you take a screenshot and add that to the thread?
    Matt McGuire
    Aquitas Solutions
  • 5.  RE: Using MxLoader to Load Assets on Job Plans > Work Assets Tab
    Posted 02-21-2022 11:14
    Edited by Tim Ferrill 02-21-2022 11:15
    Stevie,
    Edit: Matt beat me to it, and I agree with his answer.
    This should be a relatively straightforward exercise. You'd need to have an Object Structure that included the Work Assets, and ensure any alias conflicts are resolved so you can use a flat structure.
    When customizing Object Structures I'd typically recommend duplicating one to modify rather than messing with one that exists and potentially breaking something.
    Tim Ferrill
    Solutions Consultant
    Intelligent Technology Solutions
    tferrill@webuildits.com
    www.webuildits.com
    @tferrill/@webuildits
