Microsoft Visual Basic - Run-time error '91' in Mx Loader 8.3.4
  • 1.  Microsoft Visual Basic - Run-time error '91' in Mx Loader 8.3.4
    Posted 04-14-2022 14:12
      |   view attached
    When I try running the Mx Loader 8.3.4, I get the run-time error '91'.
    Object variable or With block variable not set
    I am able to establish a successful connection. I get this error when I run my Mx sheets for any operation. Any suggestions on what is wrong here?
    Best Regards,
    Vikrant K.
    Vikrant Kushwaha
    Savvy Logic Tech Consultants Corp
  • 2.  RE: Microsoft Visual Basic - Run-time error '91' in Mx Loader 8.3.4
    Posted 04-15-2022 08:52
    MXL_ASSET is not a delivered object structure. This does not look like the error if the object structure is not present, but it may be good to confirm it is setup up correctly for integration. Just a guess at this point, as I have not seen this error before.
  • 3.  RE: Microsoft Visual Basic - Run-time error '91' in Mx Loader 8.3.4
    Posted 04-18-2022 11:36
    Hi Christopher,
    MXL_ASSET is a custom object structure, but I encounter this error even with the out-of-box object structures. I have verified this object structure and it works fine with Mx Loader 6.2. I am only getting this error with Mx Loader 8.3.4. Do you suggest anything else I can verify with the configuration?
    Thank you for your assistance!
    Vikrant Kushwaha
  • 4.  RE: Microsoft Visual Basic - Run-time error '91' in Mx Loader 8.3.4
    Posted 04-20-2022 14:12
    @Vikrant Kushwaha I wish I knew more. Perhaps someone with the visual basic knowledge will understand the error and be able to interpret it. ​
  • 5.  RE: Microsoft Visual Basic - Run-time error '91' in Mx Loader 8.3.4
    Posted 05-04-2022 19:16
    Hi, There is any new about this? I wonder if you can share me older versions of Mxloader like 8.3 or 8.2
    best regards
    Ricardo Monsivais
    NA
  • 6.  RE: Microsoft Visual Basic - Run-time error '91' in Mx Loader 8.3.4
    Posted 05-05-2022 09:59
      |   view attached
    Hi Ricardo,
    I dont have any news about the error but I am attaching the version you requested (8.2).
    Hope it helps.
    Regards
    André Cordeiro
    Attachment(s)
    xlsm
    MxLoader_82.xlsm   553 KB 1 version
  • 7.  RE: Microsoft Visual Basic - Run-time error '91' in Mx Loader 8.3.4
    Posted 05-17-2022 04:39
    Hi Vikrant,
    I have a similar issue, did you already find a solution to the problem?
    Fred
    Fred Aklamanu
  • 8.  RE: Microsoft Visual Basic - Run-time error '91' in Mx Loader 8.3.4
    Posted 06-27-2022 12:21
    Has anyone found a resolution to this issue. I am encountering the same in MxLoader 8.3.5.
    Stevie
    Stevie Holloway
    U.S. Bureau of Reclamation
  • 9.  RE: Microsoft Visual Basic - Run-time error '91' in Mx Loader 8.3.4
    Posted 07-05-2022 11:55
    All Concerned:
    I don't know if the resolution below will solve others encountering the same error message but it worked for my situation.
    1. Since my configuration is LDAP, I ensured System Properties > Global Property mxe.useAppServerSecurity = 1
    2. In MxLoader, I set the Authentication to LDAP and entered my User and Password info. Next, I tested the connection which returned successful. I then executed a query and results returned without error.
    I hope this information helps others.
    Stevie
    Stevie Holloway
  • 10.  RE: Microsoft Visual Basic - Run-time error '91' in Mx Loader 8.3.4
    Posted 08-09-2022 12:47
    All,
    This may or may not apply to your particular situation. I also encountered this error and was able to work through it by referencing the article below:
    https://www.ibm.com/support/pages/mif-object-structure-authorization
    The above is for Maximo versions 7.6.0.5 +
    I had to set the system property: mxe.int.enableosauth to a value of 0 meaning that object structure authorization is not required
    Jess Schmitz
  • 11.  RE: Microsoft Visual Basic - Run-time error '91' in Mx Loader 8.3.4
    Posted 04-10-2023 13:29
    Hi Vikrant,
    Did you get this solution of this problem?
    I am getting same error.
    Kumari Annoo
    MCt India infotech
