  • 1.  Fetch query results through automation script
    Posted 05-15-2023 02:22
    I require your valuable suggestions on this:
    There are several select queries that we run in sql to check if everything is going well. Queries like if workorders have been generated from pms, through the pmwogen cron, if reorder is running properly, etc. Is it possible to run fetch the results of these queries in an email attachment through an automation script?
    Please reply
    #Analytics
    #Architecture
    #CivilInfrastructure
    #HSE/OilandGas
    #Infrastructure
    #IoT
    #LifeScience/Calibration
    #Linear
    #MaximoForAviation
    #Nuclear
    #Procurement
    #Scheduling
    #Security
    #ServiceProvider
    #Spatial
    #Transportation
    #Utilities
    #WorkCenters
    Deepa P
  • 2.  RE: Fetch query results through automation script
    Posted 05-16-2023 09:02
    If you're looking for the results of queries through a scheduled email attachment, then creating a BIRT report with the query results might be the best course. You can then schedule the reports to be run and emailed to you on a regular basis without the need for an automation script.
    Hope this helps,
    Alex Walter
    A3J Group, LLC
  • 3.  RE: Fetch query results through automation script
    Posted 05-16-2023 10:57
    Edited by Deepa P 05-16-2023 10:58
    Thank you for your response. We actually do not use birt reports here so i was trying to find some other way. Can you help me , how do i retrieve the data from sql through automation script( this is totally new to me) ?
    Deepa P
  • 4.  RE: Fetch query results through automation script
    Posted 05-16-2023 09:03
    Yes it is possible to gather that type of information and send it.
    Is there a specific reason why you want to use a script using automation scripts?
    BIRT reports provide the same opportunities and have more out of the box options e.g. schedule the report and send it in a variety of formats
    The BIRT report can be customised to read the data and then add extra information e.g. query the crontask instance table to retrieve details about a PM that experienced problems
    mark robbins
    Cohesive
  • 5.  RE: Fetch query results through automation script
    Posted 05-16-2023 19:52
    Below is a script that exports a Java ResultSet to an Excel spreadsheet with an example of emailing the results. It includes the column names as the headers, makes them bold and uses the auto width for the column so it should be formatted correctly.  It also formats dates and times according to your Maximo configuration.
    I have includes the scriptConfig variable so you can deploy it using the VS Code Maximo Development Tools extension https://marketplace.visualstudio.com/items?itemName=sharptree.maximo-script-deploy
    If you have questions please feel free to reach out. You can find other automation script examples on our blog, https://www.sharptree.io/blog
    Jason
    Boolean = Java.type("java.lang.Boolean")
    ByteArrayOutputStream = Java.type('java.io.ByteArrayOutputStream');
    Types = Java.type('java.sql.Types');
    ZoneId = Java.type("java.time.ZoneId");
    Date = Java.type("java.util.Date");
    Properties = Java.type("java.util.Properties")
    DataHandler = Java.type("javax.activation.DataHandler")
    Message = Java.type("javax.mail.Message")
    Session = Java.type("javax.mail.Session")
    InternetAddress = Java.type("javax.mail.internet.InternetAddress")
    MimeBodyPart = Java.type("javax.mail.internet.MimeBodyPart")
    MimeMessage = Java.type("javax.mail.internet.MimeMessage")
    MimeMultipart = Java.type("javax.mail.internet.MimeMultipart")
    Transport = Java.type("javax.mail.Transport")
    ByteArrayDataSource = Java.type("javax.mail.util.ByteArrayDataSource")
    Cell = Java.type('org.apache.poi.ss.usermodel.Cell');
    Row = Java.type('org.apache.poi.ss.usermodel.Row');
    XSSFSheet = Java.type('org.apache.poi.xssf.usermodel.XSSFSheet');
    XSSFWorkbook = Java.type('org.apache.poi.xssf.usermodel.XSSFWorkbook');
    XSSFFont = Java.type('org.apache.poi.xssf.usermodel.XSSFFont');
    DBShortcut = Java.type('psdi.mbo.DBShortcut');
    MXServer = Java.type('psdi.server.MXServer');
    SmtpAuthenticator = Java.type("psdi.server.MXServer$SmtpAuthenticator")
    CommonUtil = Java.type("psdi.util.CommonUtil")
    HTML = Java.type("psdi.util.HTML")
    MXFormat = Java.type("psdi.util.MXFormat");
    main();
    function main() {
        var data;
        var db = new DBShortcut();
        try {
            db.connect(MXServer.getMXServer().getSystemUserInfo().getConnectionKey());
            var rs = db.executeQuery("select personid, displayname, status, statusdate, hiredate from person");
            var data = exportResultSet(rs);
            sendEmail("badaddress@sharptree.io", "maximo@sharptree.io", "Export of Person Table", "Jason,\n\nPlease find attached an export of the Maximo person table.\n\nRegards,\nMaximo", data);
        } finally {
            db.close();
        return;
     * Send an email with an Excel workbook attachment.
     * @param  {String} to The to email address
     * @param  {String} from The from email address
     * @param  {String} subject The subject for the email
     * @param  {String} message The message for the email
     * @param  {byte[]} workbook A Java byte array representing the Apache POI Excel workbook.
     * @param  {String} attacmentName An optional attachment name, if not included "export.xlsx" is used.
    function sendEmail(to, from, subject, message, workbook, attachmentName) {
        if (!to) {
            throw Error("The to email address is required.");
        if (!from) {
            throw Error("The from email address is required.");
        if (!subject) {
            throw Error("A subject is required.");
        if (!message) {
            throw Error("A message body is required.");
        if (!workbook) {
            throw Error("A workbook attachment is required.");
        if (!attachmentName) {
            attachmentName = 'export.xlsx';
        var session = _getMailSession();
        var mimeMessage = new MimeMessage(session);
        mimeMessage.addHeaderLine("method=REQUEST");
        mimeMessage.addHeaderLine("charset=UTF-8");
        mimeMessage.setFrom(new InternetAddress(from));
        mimeMessage.addRecipient(Message.RecipientType.TO, new InternetAddress(to));
        mimeMessage.setSentDate(MXServer.getMXServer().getDate());
        var charset = MXServer.getMXServer().getProperty("mxe.email.charset");
        var charsetAvailable = typeof charset !== 'undefined' && !charset.isEmpty();
        // if the subject was provided then remove new lines
        if (typeof subject !== 'undefined' && !subject.isEmpty()) {
            subject = CommonUtil.removeNewLines(subject);
            // if the charset was available then use it, otherwise allow the system default to be used.
            if (charsetAvailable) {
                mimeMessage.setSubject(subject, charset);
            } else {
                mimeMessage.setSubject(subject);
        var multipart = new MimeMultipart();
        // if a non-empty message was provided then add it as the first message part.
        if (typeof message !== 'undefined' && !message.isEmpty()) {
            var mimeMessagePart = new MimeBodyPart();
            var emailContentType = MXServer.getMXServer().getConfig().getProperty("mxe.email.content.type");
            var convertToPlainText = MXServer.getMXServer().getConfig().getProperty("mxe.email.convertToPlainText");
            if (!"text/html".equalsIgnoreCase(emailContentType) && Boolean.parseBoolean(equalsIgnoreCase(convertToPlainText))) {
                message = HTML.toPlainText(message);
            } else if (!HTML.isHtml(message) || HTML.isHtml(message) && !HTML.containsHtmlBreakTags(message)) {
                message = HTML.replaceNewLineWithBR(message);
            if (emailContentType) {
                    mimeMessagePart.setText(message, charset);
                    mimeMessagePart.setHeader("Content-Type", emailContentType + ";charset=" + charset);
                } else {
                    mimeMessagePart.setText(message);
                    mimeMessagePart.setHeader("Content-Type", emailContentType);
            } else if (charsetAvailable) {
            } else {
            // add the message part to the multipart message.
            multipart.addBodyPart(mimeMessagePart);
            var attachment = new MimeBodyPart();
            // add the Excel workbook message to the invite multi part.
            attachment.setDataHandler(new DataHandler(new ByteArrayDataSource(workbook, 'application/vnd.ms-excel;name="' + attachmentName + '"')));
            multipart.addBodyPart(attachment);
            mimeMessage.setContent(multipart);
            var sslEnabled = Boolean.parseBoolean(MXServer.getMXServer().getProperty("mail.smtp.ssl.enable"));
            // if ssl is enabled send it via https otherwise just send the message.
            if (sslEnabled) {
                var transport = session.getTransport("smtps");
                transport.connect();
                transport.sendMessage(mimeMessage, mimeMessage.getAllRecipients());
                transport.close();
            } else {
                Transport.send(mimeMessage);
     * Exports the provided ResultSet to an Excel workbook.  Returns a Java byte array representing the workbook.
     * @param  {ResultSet} resultSet The Java JDBC ResultSet to export to Excel
     * @param  {String} sheetName An optional name for the workbook sheet, defaults to the table name of the first column in the result set.
    function exportResultSet(resultSet, sheetName) {
        if (!resultSet) {
            return null;
        var metadata = resultSet.getMetaData();
        var columnCount = metadata.getColumnCount()
        var columns = [];
        var types = [];
        for (var i = 1; i <= columnCount; i++) {
            columns.push(metadata.getColumnLabel(i));
            types.push(metadata.getColumnType(i));
        var workbook = new XSSFWorkbook();
        var font = workbook.createFont();
        font.setBold(true);
        style = workbook.createCellStyle();
        style.setFont(font);
        var sheet = workbook.createSheet(sheetName ? sheetName : metadata.getTableName(1));
        var headers = sheet.createRow(0);
        for (i = 0; i < columnCount; i++) {
            var header = headers.createCell(i);
            header.setCellValue(columns[i]);
            header.setCellStyle(style);
        var rowIndex = 1;
        while (resultSet.next()) {
            var row = sheet.createRow(rowIndex++);
            for (var j = 0; j < columnCount; j++) {
                var value = resultSet.getString(j + 1);
                if (value) {
                    switch (types[j]) {
                        case Types.DATE:
                            row.createCell(j).setCellValue(MXFormat.dateToString(Date.from(resultSet.getDate(j + 1).toLocalDate().atStartOfDay(ZoneId.systemDefault()).toInstant())));
                            break;
                        case Types.TIMESTAMP:
                            var value = resultSet.getTimestamp(j + 1);
                            row.createCell(j).setCellValue(MXFormat.dateToString(Date.from(resultSet.getTimestamp(j + 1).toInstant())) + " " + MXFormat.timeToString(Date.from(resultSet.getTimestamp(j + 1).toInstant())));
                            break;
                        case Types.SMALLINT:
                        case Types.INTEGER:
                            row.createCell(j).setCellValue(resultSet.getInt(j + 1));
                            break;
                        case Types.BIGINT:
                            row.createCell(j).setCellValue(resultSet.getLong(j + 1));
                            break;
                        case Types.DECIMAL:
                        case Types.FLOAT:
                        case Types.NUMERIC:
                        case Types.DOUBLE:
                            row.createCell(j).setCellValue(resultSet.getDouble(j + 1));
                            break;
                        default:
                            row.createCell(j).setCellValue(value);
                            break;
            sheet.autoSizeColumn(j);
        var out = new ByteArrayOutputStream();
        workbook.write(out);
        workbook.close();
        return out.toByteArray();
    // Use the Maximo properties to manually establish a new JavaMail session that can be used directly.
    function _getMailSession() {
        var mailProps = new Properties();
        // Copy all the properties from the system config to a new variable that we can change.
        mailProps.putAll(MXServer.getMXServer().getMxServerConfig());
        var smtpHost = null;
        smtpHost = MXServer.getMXServer().getProperty("mail.smtp.host");
        if (smtpHost != null && !smtpHost.isEmpty()) {
            mailProps.put("mail.smtp.host", smtpHost);
        if (sslEnabled) {
            mailProps.put("mail.transport.protocol", "smtps");
            mailProps.put("mail.smtps.ssl.enable", sslEnabled);
            mailProps.put("mail.smtps.socketFactory.port", MXServer.getMXServer().getProperty("mail.smtp.port"));
            mailProps.put("mail.smtps.socketFactory.class", "javax.net.ssl.SSLSocketFactory");
            mailProps.put("mail.smtps.socketFactory.fallback", "false");
        var user = MXServer.getMXServer().getProperty("mxe.smtp.user");
        var password = MXServer.getMXServer().getProperty("mxe.smtp.password");
        if (user != null && !user.isEmpty()) {
            mailAuth = new SmtpAuthenticator(MXServer.getMXServer(), user, password);
        } else {
            mailAuth = null;
        if (mailAuth != null) {
            mailProps.put("mail.smtp.auth", "true");
        var smtpTimeout = MXServer.getMXServer().getProperty("mxe.smtp.timeout");
        if (smtpTimeout != null && !smtpTimeout.isEmpty()) {
            mailProps.put("mail.smtp.timeout", smtpTimeout);
        var smtpConnectionTimeout = MXServer.getMXServer().getProperty("mxe.smtp.connectiontimeout");
        if (smtpConnectionTimeout != null && !smtpConnectionTimeout.isEmpty()) {
            mailProps.put("mail.smtp.connectiontimeout", smtpConnectionTimeout);
        mailProps.put("mail.smtp.sendpartial", mailProps.getProperty("mail.smtp.sendpartial").equals("0") ? "false" : "true");
        return Session.getInstance(mailProps, mailAuth);
    var scriptConfig = {
        "autoscript": "SHARPTREE.EXCEL.EXPORT",
        "description": "Sharptree excel export script.a",
        "version": "",
        "active": true,
        "logLevel": "ERROR"
    Jason VenHuizen
    Sharptree
  • 6.  RE: Fetch query results through automation script
    Posted 05-21-2023 14:31
    After giving it a bit more thought I abstracted this into a library that exports both ResultSets and MboSets.  Samples are included for both.
    https://github.com/sharptree/autoscript-library/tree/main/excel
    Jason VenHuizen
    Sharptree
