Hi Mahadevan,
I have achieved this through DOCLINKS configuration by following the below steps:
1) Created Signature Options and Actions: 'ASSOCFOLD', 'MANAGEFOLD', 'MANAGELIB'
2) Created Relationship with DOCLINKS child object.
3) Given Permissions for the Signature Options in Security Group.
4) Associated folders for the application.
5) Restated the server.
The same Configurations worked in our test environment but giving this error in the client environment. Major change is the Version difference between the test environment and client environment. Could this be the cause?
Harshavardhan Kamepalli
Eidiko System Integrators
Sent: 11-21-2021 07:31
Subject: Attachments 'No file selected' Error
Could you please let us know if you achieved this through configuration? Please enable the loggers to debug mode and that will give you the hint as to what went wrong and you can take it from there.
Mahadevan Ramakrishnan
Sent: 11-19-2021 06:34
I have applied the attachments functionality to a custom application in Maximo and when uploading file, I am getting this message 'No File selected' even when I select a file from Browse and click Ok.
Anyone know the root-cause and resolution for this issue? Any help is appreciated
