  • 1.  How to have required default data in all work order
    Posted 16 days ago
    Hi everyone,
       I want to have default data in long description  for all work-order created by the user (excluding the PM generated Workorders) Is it possible in MAXIMO.
    Divakar Mani
    Qaiwan Group
  • 2.  RE: How to have required default data in all work order
    Maximo Certified
    Posted 15 days ago
    Have you thought about using an automation script?  The question is when do you need it to fire.
    ISW
    Maximo Practice Manager
    eMail: ckokay@isw.net.au
    Phone: +61-411-682-040
    #IBMChampion2022
  • 3.  RE: How to have required default data in all work order
    Maximo Certified
    Posted 15 days ago
    What is the value in storing the same data multiple times? Defaults can make sense (setting a default insert site, setting a user's default storeroom, etc.) but storing a string of text over and over increases the size of the database without providing value. It'd be better to store this somewhere and display it via a relationship rather than duplicate it in the long description.
    If defaulting is required, you could create a script called WORKORDER.NEW and that would default when a record is added immediately (so a user could change it if necessary before saving).
    To check if a PM is generating, you need to import MXServer (from psdi.server import MXServer) and add a check like
    if MXServer.getBulletinBoard().isPosted("PM.GeneratingWork")
