I think you are probably not sending the correct WSDL function.Cannot deliver means the WS Client(the test tool) couldn't understand the
WSDL corrrectly. For e.g when you fire a SOAPUI request since I will show you my application which is JAXWSHANDLER based
So when you use SOAPUI switch to the RAW on that interface so it will show you the SERVICENAME & SOAPACTION
if not try to see what your WSDL soap action is
Also, increase the integration logger to DEBUG so you will be able to see what the call is.
The key is to find from SOAPUI or custom code(like java or C# SOAP client) what is the actual SOAP Action
and service the WS client code is invoking. Inside the handler class, you will see that what you pass to the call is
going to somehow invoke a call like this
resp = wsClient.invoke(data, configuredServiceName, configuredEndpointURL, configuredSoapAction,
this.getSoapVersion(), configuredUserName, configuredPassword, this.getMsgExPtrn(),
(Map) httpHeaders, this.getHttpReadTimeout(), (Map) soapRequestHeaders,
(Map) soapResponseHeaders); as you can see if you specify a parameter incorrectly or null it
then maximo will not do anything on your behalf.It will just process it the way
So the key is to get the fine glue of how your SAP SOAP call works as Maximo is pretending to be
a client to that. The Errors in Maximo is hard for me to understand so I wouldn't comment on whether Maximo is
at fault.
I had these frustrating moments myself where IBM Maximo support doesn't give you much in the way of real-world examples
as well as the other side also won't give you much help. That is why I started digging into the "Maximo code".If that SAP WSDL is something very much SAP helps troubleshoot then I think all you need is some more trial and error with SOAPUI headers, service name, etc...
If I were you I would create a simple.NET soap client and make the call work with SAP. I would then observe the SOAP payload (using fiddler when the C# code runs) completely with headers, service names, etc, and then try to attempt Maximo with that info.
One of the things I learned is with SOAPUI you can fake a receiving endpoint so when a successful message is received by SOAPUI you can see logs. majority of the time when the Maximo test interface fails soapui doesn't even have anything which is how I methodically tackled my problem. (In my case Maximo was showing an error and soapui doesn't receive anything so I was able to find the problem had to be sorted in Maximo itself:)
Appu nair
APPECM
Sent: 05-28-2021 01:43
Subject: Automation Script to pass Request to External System using WSDL url
Hi Appu Nair,
As you suggested, was working with WEBSERVICE and WEBSERVICE-JAXWS handlers to create the End Point and test it with request and I was receiving same error with both Handlers:
Does this mean, the problem is with External System?
These are details of the End Point.
Harshavardhan Kamepalli
Eidiko System Integrators
Sent: 05-27-2021 09:17
Some suggestions as I went through this 6 months or earlier spoken from memory.
- Take a working soap message that works seamlessly in SOAPUI without any bearing on Maximo. Use the exact identical message in the two handlers you see JAXWSHandler and WebService Handler and HTTP in that TEST utility. Create one of each while you test this. Pay special attention to what the SOAPUI debugger tells you vis-à-vis headers etc. If you land on one of those working handler types now you know it is just a matter of time.
- Now concentrate on your XSL or java class because all it is doing is take the translated message and using the Handler as you tested in that test button utility. That is incidentally how I was able to progress and understand what was wrong with my approach.
- Some integration in SAP uses the HTTP Endpoint but in my design, I adopted the JAXWSHANDLER because it was more suited for my SOAP envelope.
My $0.02
Appu nair
APPECM
Sent: 05-27-2021 08:42
Hi Alex,
I have transformed the Maximo XML to SAP format by using online XSLT transformation tool and got the correct SAP format which by testing with SOAPUI created a incident ticket in SAP SOLMAN.
Transformed XML using XSLT:
<?xml version="1.0" encoding="UTF-8"?><soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/" xmlns:urn="urn:sap-com:document:sap:soap:functions:mc-style" xmlns:mro="http://www.ibm.com/maximo"> <soapenv:Header/> <soapenv:Body> <urn:ProcessIncident> <IctAdditionalInfos/> <IctAttachments/> <IctHead> <IncidentGuid>00155D433C321EDBAFA5E005B59C16DA</IncidentGuid> <RequesterGuid>9219F59AC585431AB7D6DDA03EA520AA</RequesterGuid> <ProviderGuid>00155D433C321EDBAF8A2AD9D8A220DA</ProviderGuid> <AgentId/> <ReporterId>SPILLI</ReporterId> <ShortDescription>Sample Incident Record from Integration</ShortDescription> <Priority>1</Priority> <Language>EN</Language> <RequestedBegin>20210525073107</RequestedBegin> <RequestedEnd>20210525073107</RequestedEnd> </IctHead> <IctId>3</IctId> <IctPersons> <item> <PersonId>SPILLI</PersonId> <PersonIdExt/> <Sex/> <FirstName/> <LastName/> <Telephone> <PhoneNo/> <PhoneNoExtension/> </Telephone> <MobilePhone/> <Fax> <FaxNo/> <FaxNoExtension/> </Fax> <Email/> </item> </IctPersons> <IctSapNotes/> <IctSolutions/> <IctStatements> <item> <TextType/> <Texts/> <Timestamp>20210525073107</Timestamp> <PersonId>SPILLI</PersonId> <Language>EN</Language> </item> </IctStatements> <IctTimestamp>20210525073107</IctTimestamp> <IctUrls/> </urn:ProcessIncident> </soapenv:Body></soapenv:Envelope>
And there is no data in the Soap Header too.
Shall I add "soapAction='Add'" in the header instead of "Content-Type: text/xml"
Sent: 05-27-2021 08:31
Check the headers in your End Point setup in Maximo. You likely need a soapAction header. You should be able to see the headers that SOAPUI is injecting into the request, and should be able to copy the soapAction header.
As for the parse error, I think there's a bug in the XSLT file. I believe those REPORTEDBY, DESCRIPTION, and AFFECTEDPERSON translations still need to be wrapped in tags. Instead of:
<AgentId></AgentId><xsl:apply-templates select="mro:REPORTEDBY"/><xsl:apply-templates select="mro:DESCRIPTION"/><Priority>1</Priority>
... it should be something like:
<AgentId></AgentId><ReportedBy><xsl:apply-templates select="mro:REPORTEDBY"/></ReportedBy><Description><xsl:apply-templates select="mro:DESCRIPTION"/></Description><Priority>1</Priority>
Hope this helps,
Alex Walter
A3J Group, LLC
Sent: 05-27-2021 00:17
Thanks Alex, I already followed your process of XSLT transformation and successfully transformed the Maximo XML format to SAP format.
Maximo Message(Simplified Object Structure of Incident):
<?xml version="1.0" encoding="UTF-8"?><max:PublishMXD-INCIDENT xmlns:max="http://www.ibm.com/maximo" creationDateTime="2008-09-29T02:49:45" baseLanguage="string" transLanguage="string" messageID="string" maximoVersion="string" event="0"> <max:MXD-INCIDENTSet> <max:INCIDENT action="Delete" relationship="string" deleteForInsert="string" transLanguage="string"> <max:MAXINTERRORMSG>string</max:MAXINTERRORMSG> <max:AFFECTEDPERSON changed="true">string</max:AFFECTEDPERSON> <max:CLASS maxvalue="string" changed="true">string</max:CLASS> <max:CREATEDBY changed="true">string</max:CREATEDBY> <max:DESCRIPTION changed="false">string</max:DESCRIPTION> <max:REPORTDATE changed="false">2009-05-16T13:42:28</max:REPORTDATE> <max:REPORTEDBY changed="false">string</max:REPORTEDBY> <max:SOURCE changed="true">string</max:SOURCE> <max:TICKETID changed="false">string</max:TICKETID> </max:INCIDENT> </max:MXD-INCIDENTSet></max:PublishMXD-INCIDENT>
My XSLT code:
<?xml version='1.0'?><xsl:stylesheet version='1.0' xmlns:xsl="http://www.w3.org/1999/XSL/Transform" xmlns:mro="http://www.ibm.com/maximo"> <xsl:output method="xml" omit-xml-declaration="no" indent="yes" encoding="UTF-8"/> <xsl:template match="/"> <xsl:apply-templates select="mro:PublishMXD-INCIDENT"/> </xsl:template> <xsl:template match="mro:PublishMXD-INCIDENT"> <xsl:apply-templates select="mro:MXD-INCIDENTSet"/> </xsl:template> <xsl:template match="mro:MXD-INCIDENTSet"> <xsl:apply-templates select="mro:INCIDENT"/> </xsl:template> <xsl:template match="mro:INCIDENT"> <soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/" xmlns:urn="urn:sap-com:document:sap:soap:functions:mc-style"> <soapenv:Header/> <soapenv:Body> <urn:ProcessIncident> <IctAdditionalInfos/> <IctAttachments/> <IctHead> <IncidentGuid>00155D433C321EDBAFA5E005B59C16DA</IncidentGuid> <RequesterGuid>9219F59AC585431AB7D6DDA03EA520AA</RequesterGuid> <ProviderGuid>00155D433C321EDBAF8A2AD9D8A220DA</ProviderGuid> <AgentId></AgentId> <xsl:apply-templates select="mro:REPORTEDBY"/> <xsl:apply-templates select="mro:DESCRIPTION"/> <Priority>1</Priority> <Language>EN</Language> <RequestedBegin>20210525073107</RequestedBegin> <RequestedEnd>20210525073107</RequestedEnd> </IctHead> <IctId>3</IctId> <IctPersons> <item> <xsl:apply-templates select="mro:AFFECTEDPERSON"/> <PersonIdExt></PersonIdExt> <Sex></Sex> <FirstName></FirstName> <LastName></LastName> <Telephone> <PhoneNo></PhoneNo> <PhoneNoExtension></PhoneNoExtension> </Telephone> <MobilePhone></MobilePhone> <Fax> <FaxNo></FaxNo> <FaxNoExtension></FaxNoExtension> </Fax> <Email></Email> </item> </IctPersons> <IctSapNotes/> <IctSolutions/> <IctStatements> <item> <TextType/> <Texts/> <Timestamp>20210525073107</Timestamp> <xsl:apply-templates select="mro:AFFECTEDPERSON"/> <Language>EN</Language> </item> </IctStatements> <IctTimestamp>20210525073107</IctTimestamp> <IctUrls/> </urn:ProcessIncident> </soapenv:Body> </soapenv:Envelope> </xsl:template> <xsl:template match="mro:REPORTEDBY"> <ReporterId><xsl:value-of select="."/></ReporterId> </xsl:template> <xsl:template match="mro:AFFECTEDPERSON"> <PersonId><xsl:value-of select="."/></PersonId> </xsl:template> <xsl:template match="mro:DESCRIPTION"> <ShortDescription><xsl:value-of select="."/></ShortDescription> </xsl:template></xsl:stylesheet>
When I test the output of this transformation with SOAPUI, I can create a ticket on the SAP Environment but when I try it do through maximo Publish Channel, it is not working and I am not sure of the mistake I am doing here.
The following are the details of End Point and Publish Channels I created in maximo.
End Point:
Publish Channel:
I Copied the XSL file into all the servers of the Cluster.
I also wrote script on Incident Object Launch Point after Save to export data
from psdi.server import MXServerfrom psdi.mbo import Mboserver = MXServer.getMXServer()userInfo = mbo.getUserInfo()whereClause = "status='NEW'"server.lookup("MIC").exportData("SOLMAN", "SOLMAN", whereClause, userInfo, 1000)print "Successful XML"
And also when I test the End Point by the request that I am testing through SOAPUI, it returns the below error.
I don't understand why it is not working, Is there anything else I need to do? Any mistake I am doing in the End point or publish channel details?
Should I make any Configurations in the WAS console Service Integration section, I was reading Alex's 'Top 6 Things to check if your Integration is not Working' and i noticed 'Message Tracking and Repocessing' section.
Update: Was Checking logs when I triggered the data Export script by creating Incident, I saw this error message everytime:
[5/27/21 6:00:12:086 WAT] 004f215d SystemOut O 27 May 2021 06:00:12:086 [INFO] [MAXIMO] [] ScriptMboEventListener Event maximo.incident.add has been fired for script SOLMAN launch point SOLMAN[5/27/21 6:00:13:024 WAT] 004f215d SystemOut O 27 May 2021 06:00:13:024 [INFO] [MAXIMO] [] Name E:\IBM\SMP\maximo\mif\SAPINC.xsl[5/27/21 6:00:13:070 WAT] 004f215d SystemOut O 27 May 2021 06:00:13:070 [ERROR] [MAXIMO] [] Invalid Expressionjava.lang.RuntimeException: Invalid Expression at psdi.iface.stax.MXStAXParser.evaluateXPath(MXStAXParser.java:295) at psdi.iface.stax.MXStAXParser.evaluateXPath(MXStAXParser.java:436) at psdi.iface.jms.MEAQueueProcessor.writeDataToQueue(MEAQueueProcessor.java:192) at psdi.iface.mic.PublishChannel.processStructure(PublishChannel.java:491) at psdi.iface.mic.PublishChannel.publishTo(PublishChannel.java:406) at psdi.iface.mic.EntMicService.exportData(EntMicService.java:952) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:90) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:55) at java.lang.reflect.Method.invoke(Method.java:508) at org.python.core.PyReflectedFunction.__call__(PyReflectedFunction.java:186) at org.python.core.PyObject.__call__(PyObject.java:419) at org.python.core.PyMethod.instancemethod___call__(PyMethod.java:237) at org.python.core.PyMethod.__call__(PyMethod.java:228) at org.python.core.PyMethod.__call__(PyMethod.java:218) at org.python.pycode._pyx175.f$0(<script>:7) at org.python.pycode._pyx175.call_function(<script>) at org.python.core.PyTableCode.call(PyTableCode.java:167) at org.python.core.PyCode.call(PyCode.java:18) at org.python.core.Py.runCode(Py.java:1386) at org.python.core.__builtin__.eval(__builtin__.java:497) at org.python.core.__builtin__.eval(__builtin__.java:501) at org.python.util.PythonInterpreter.eval(PythonInterpreter.java:259) at org.python.jsr223.PyScriptEngine.eval(PyScriptEngine.java:40) at org.python.jsr223.PyScriptEngine.access$300(PyScriptEngine.java:20) at org.python.jsr223.PyScriptEngine$PyCompiledScript.eval(PyScriptEngine.java:231) at com.ibm.tivoli.maximo.script.JSR223ScriptDriver.evalScript(JSR223ScriptDriver.java:274) at com.ibm.tivoli.maximo.script.AbstractScriptDriver.runScript(AbstractScriptDriver.java:155) at com.ibm.tivoli.maximo.script.ScriptMboEventListener.postSaveInternalEventAction(ScriptMboEventListener.java:392) at psdi.server.event.EventTopic$Subscription.postSaveInternalEventAction(EventTopic.java:751) at psdi.server.event.EventTopic.postSaveInternalEventAction(EventTopic.java:441) at psdi.server.event.EventTopicTree.postSaveInternalEventAction(EventTopicTree.java:917) at psdi.mbo.Mbo.fireEvent(Mbo.java:6335) at psdi.mbo.StatefulMbo.fireEvent(StatefulMbo.java:799) at psdi.mbo.MboSet.fireEventsAfterDB(MboSet.java:7993) at psdi.txn.MXTransactionImpl.fireEventsAfterDB(MXTransactionImpl.java:456) at psdi.txn.MXTransactionImpl.saveTransaction(MXTransactionImpl.java:229) at psdi.txn.MXTransactionImpl.save(MXTransactionImpl.java:156) at psdi.mbo.MboSet.save(MboSet.java:7533) at psdi.mbo.MboSet.save(MboSet.java:7457) at psdi.webclient.system.beans.AppBean.save(AppBean.java:642) at psdi.webclient.system.beans.AppBean.SAVE(AppBean.java:1338) at psdi.plusp.webclient.beans.common.PlusPTicketAppBean.SAVE(PlusPTicketAppBean.java:42) at com.ibm.tsd.pminc.webclient.beans.PmIncidentAppBean.SAVE(PmIncidentAppBean.java:734) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:90) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:55) at java.lang.reflect.Method.invoke(Method.java:508) at psdi.webclient.system.session.WebClientSession.defaultHandler(WebClientSession.java:1507) at psdi.webclient.system.session.WebClientSession.handleEvent(WebClientSession.java:1400) at psdi.webclient.system.session.WebClientSession.processRequestEvent(WebClientSession.java:6143) at psdi.webclient.system.session.WebClientSession.handleClientSideQueueRequest(WebClientSession.java:6099) at psdi.webclient.system.session.WebClientSession.handleRequest(WebClientSession.java:889) at psdi.webclient.system.session.AsyncRequestManager.handleRequest(AsyncRequestManager.java:555) at psdi.webclient.system.session.AsyncRequestManager.manageRequest(AsyncRequestManager.java:253) at psdi.webclient.system.controller.RequestManager.manageRequest(RequestManager.java:232) at psdi.webclient.servlet.WebClientServlet.handleRequest(WebClientServlet.java:141) at psdi.webclient.servlet.WebClientServlet.doPost(WebClientServlet.java:52) at javax.servlet.http.HttpServlet.service(HttpServlet.java:707) at javax.servlet.http.HttpServlet.service(HttpServlet.java:790) at com.ibm.ws.webcontainer.servlet.ServletWrapper.service(ServletWrapper.java:1235) at com.ibm.ws.webcontainer.servlet.ServletWrapper.handleRequest(ServletWrapper.java:779) at com.ibm.ws.webcontainer.servlet.ServletWrapper.handleRequest(ServletWrapper.java:478) at com.ibm.ws.webcontainer.servlet.ServletWrapperImpl.handleRequest(ServletWrapperImpl.java:178) at com.ibm.ws.webcontainer.filter.WebAppFilterChain.invokeTarget(WebAppFilterChain.java:143) at com.ibm.ws.webcontainer.filter.WebAppFilterChain.doFilter(WebAppFilterChain.java:96) at psdi.webclient.system.filter.HttpCrossSiteScriptingSecurity.doFilter(HttpCrossSiteScriptingSecurity.java:66) at com.ibm.ws.webcontainer.filter.FilterInstanceWrapper.doFilter(FilterInstanceWrapper.java:197) at com.ibm.ws.webcontainer.filter.WebAppFilterChain.doFilter(WebAppFilterChain.java:90) at psdi.webclient.system.filter.MXCorrelationFilter.doFilter(MXCorrelationFilter.java:137) at com.ibm.ws.webcontainer.filter.FilterInstanceWrapper.doFilter(FilterInstanceWrapper.java:197) at com.ibm.ws.webcontainer.filter.WebAppFilterChain.doFilter(WebAppFilterChain.java:90) at psdi.webclient.system.filter.PerformanceMonitor.doFilter(PerformanceMonitor.java:126) at com.ibm.ws.webcontainer.filter.FilterInstanceWrapper.doFilter(FilterInstanceWrapper.java:197) at com.ibm.ws.webcontainer.filter.WebAppFilterChain.doFilter(WebAppFilterChain.java:90) at psdi.webclient.system.filter.HttpXFrameOptionsFilter.doFilter(HttpXFrameOptionsFilter.java:38) at com.ibm.ws.webcontainer.filter.FilterInstanceWrapper.doFilter(FilterInstanceWrapper.java:197) at com.ibm.ws.webcontainer.filter.WebAppFilterChain.doFilter(WebAppFilterChain.java:90) at psdi.webclient.system.filter.MTContextFilter.doFilter(MTContextFilter.java:53) at com.ibm.ws.webcontainer.filter.FilterInstanceWrapper.doFilter(FilterInstanceWrapper.java:197) at com.ibm.ws.webcontainer.filter.WebAppFilterChain.doFilter(WebAppFilterChain.java:90) at com.ibm.ws.webcontainer.filter.WebAppFilterManager.doFilter(WebAppFilterManager.java:969) at com.ibm.ws.webcontainer.filter.WebAppFilterManager.invokeFilters(WebAppFilterManager.java:1109) at com.ibm.ws.webcontainer.webapp.WebApp.handleRequest(WebApp.java:4198) at com.ibm.ws.webcontainer.webapp.WebAppImpl.handleRequest(WebAppImpl.java:2208) at com.ibm.ws.webcontainer.webapp.WebGroup.handleRequest(WebGroup.java:304) at com.ibm.ws.webcontainer.WebContainer.handleRequest(WebContainer.java:1030) at com.ibm.ws.webcontainer.WSWebContainer.handleRequest(WSWebContainer.java:1817) at com.ibm.ws.webcontainer.channel.WCChannelLink.ready(WCChannelLink.java:382) at com.ibm.ws.http.channel.inbound.impl.HttpInboundLink.handleDiscrimination(HttpInboundLink.java:465) at com.ibm.ws.http.channel.inbound.impl.HttpInboundLink.handleNewRequest(HttpInboundLink.java:532) at com.ibm.ws.http.channel.inbound.impl.HttpInboundLink.processRequest(HttpInboundLink.java:318) at com.ibm.ws.http.channel.inbound.impl.HttpICLReadCallback.complete(HttpICLReadCallback.java:88) at com.ibm.ws.tcp.channel.impl.AioReadCompletionListener.futureCompleted(AioReadCompletionListener.java:175) at com.ibm.io.async.AbstractAsyncFuture.invokeCallback(AbstractAsyncFuture.java:217) at com.ibm.io.async.AsyncChannelFuture.fireCompletionActions(AsyncChannelFuture.java:161) at com.ibm.io.async.AsyncFuture.completed(AsyncFuture.java:138) at com.ibm.io.async.ResultHandler.complete(ResultHandler.java:204) at com.ibm.io.async.ResultHandler.runEventProcessingLoop(ResultHandler.java:775) at com.ibm.io.async.ResultHandler$2.run(ResultHandler.java:905) at com.ibm.ws.util.ThreadPool$Worker.run(ThreadPool.java:1909)
Sent: 05-26-2021 13:27
Unless I'm misunderstanding, the XSL Map feature should allow you to achieve the transformation you're looking for without the need of Automation Scripts. Check out this article:
https://a3jgroup.com/xslt-data-transformation-in-maximo/
You can transform the message into the full SAP message (including SOAP envelope) and then use the HTTP handler to deliver the message to the end point. You would likely need to specify the soapAction in the HTTP header as a parameter.
Hope this helps,
Alex Walter
A3J Group, LLC
Sent: 05-25-2021 10:04
Hi Appu Nair,
Thanks for taking your time and replying for the post.
I'm too new for Integration Scripting and actually this is my first time writing a Integration Script. So, it has become a challenge for me to understand this process.
I know that we get different XML structure to that of External System and we have to map some fields from the Maximo Outbound XML to External System Request.
Maximo XML Request Structure that a Publish Channel process:
This is what my External System Request looks like:
<soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/" xmlns:urn="urn:sap-com:document:sap:soap:functions:mc-style"> <soapenv:Header/> <soapenv:Body> <urn:ProcessIncident> <IctAdditionalInfos/> <IctAttachments/> <IctHead> <IncidentGuid>00155D433C321EDBAFA5E005B59C12DA</IncidentGuid> <RequesterGuid>9219F59AC585431AB7D6DDA03EA520AA</RequesterGuid> <ProviderGuid>00155D433C321EDBAF8A2AD9D8A220DA</ProviderGuid> <AgentId></AgentId> <ReporterId>SPILLI</ReporterId> <ShortDescription>Sample Incident Record from SOAP</ShortDescription> <Priority>1</Priority> <Language>EN</Language> <RequestedBegin>20210525073107</RequestedBegin> <RequestedEnd>20210525073107</RequestedEnd> </IctHead> <IctId>3</IctId> <IctPersons> <item> <PersonId>SPILLI</PersonId> <PersonIdExt>SPILLI</PersonIdExt> <Sex></Sex> <FirstName>Srinivas</FirstName> <LastName>Pilli</LastName> <Telephone> <PhoneNo></PhoneNo> <PhoneNoExtension></PhoneNoExtension> </Telephone> <MobilePhone></MobilePhone> <Fax> <FaxNo></FaxNo> <FaxNoExtension></FaxNoExtension> </Fax> <Email></Email> </item> </IctPersons> <IctSapNotes/> <IctSolutions/> <IctStatements> <item> <TextType>SU99</TextType> <Texts> <item>This is from SOAPUI</item> </Texts> <Timestamp>20210525073107</Timestamp> <PersonId>SPILLI</PersonId> <Language>EN</Language> </item> </IctStatements> <IctTimestamp>20210525073107</IctTimestamp> <IctUrls> </IctUrls> </urn:ProcessIncident> </soapenv:Body></soapenv:Envelope>
So, here I have to take data from the above Maximo XML when a Incident ticket is raised and Insert it some of the fields in the below Request and pass it to the External System Web Service.
I have completed the pre-requisites of creating the 'End Point', 'Publish Channel' and 'External System'. I am struck at writing the script to make the Integration happen.
The Challenge here is we do not have a middleware to transform the data from Source to External System. So, thought of using XSL Map feature.
I was scouting google for this to happen and found a script(below) to , Can we write this in an 'Action Launch Point' and place it in the workflow node to export data to the External System?
Sent: 05-25-2021 09:21
Go to to your Maximo system and look at Automation Scripts.
The Create menu will subdivide into many choices
Use Create Script for Integration.
If you are not a novice like me perhaps you will know what to write
I had a need to use SOAP in a project so I was given some good advice by the Gurus of Maximo
Open a External Website with Params from Maximo | Maximo Integration (ibm.com)
I had trouble understanding nomenclature etc on what to do.
I also changed my design because using eclipse to debug code was far easier than trying to understand scripting
so I ended up using a user exit class on my publish channel for my design so in my mind you would probably use a User Exit.
If you need to manipulate the SOAP message output for your integration I created a handler as I had to change the soap structure. My soap receiver has more requirements than usual. For e.g your soap message has an empty header tag but my system receiving maximo messages wouldn't do so.
<soapenv:Header/>
while researching I found a whole lot of material in google and IBM as well and a lot of helpful people.
Appu nair
APPECM
Sent: 05-25-2021 05:20
I have completed the following steps:
1) Created a HTTP End Point.
2) Created a Publish Channel with the Incident Object Structure which has Inbound and Outbound Processing.
3) Created a External System and selected the above created 'End Point' and 'Public Channel'.
Now, I want to know how to write an Integration Script to on this Publish Channel and dynamically pass data of the attributes like 'ReportedBy' and 'Description' of Maximo Incident Record into the following XML Request and execute the script when a new Incident is created in Maximo.
<soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/" xmlns:urn="urn:sap-com:document:sap:soap:functions:mc-style"> <soapenv:Header/> <soapenv:Body> <urn:ProcessIncident> <IctAdditionalInfos/> <IctAttachments/> <IctHead> <IncidentGuid></IncidentGuid> <RequesterGuid></RequesterGuid> <ProviderGuid></ProviderGuid> <AgentId></AgentId> <ReporterId>'REPORTEDBY'</ReporterId> <ShortDescription>'DESCRIPTION'</ShortDescription> <Priority>1</Priority> <Language>EN</Language> <RequestedBegin>20210525073107</RequestedBegin> <RequestedEnd>20210525073107</RequestedEnd> </IctHead> <IctId>3</IctId> <IctPersons> <item> <PersonId></PersonId> <PersonIdExt></PersonIdExt> <Sex></Sex> <FirstName></FirstName> <LastName></LastName> <Telephone> <PhoneNo></PhoneNo> <PhoneNoExtension></PhoneNoExtension> </Telephone> <MobilePhone></MobilePhone> <Fax> <FaxNo></FaxNo> <FaxNoExtension></FaxNoExtension> </Fax> <Email></Email> </item> </IctPersons> <IctSapNotes/> <IctSolutions/> <IctStatements> <item> <TextType>SU99</TextType> <Texts> <item>This is from SOAPUI</item> </Texts> <Timestamp></Timestamp> <PersonId></PersonId> <Language>EN</Language> </item> </IctStatements> <IctTimestamp></IctTimestamp> <IctUrls> </IctUrls> </urn:ProcessIncident> </soapenv:Body></soapenv:Envelope>
The above request creates a new Incident Request in the SAP SolMan Environment and tested it using SOAPUI.
