  • 1.  Cognos Report - Direct Print Report in WO Tracking - Report runs with Open WO
    Posted 04-08-2022 13:37
    This is my link to Cognos WO Report.
    http://cognosca.domain1.chelan/ibmcognos/bi/?pathRef=.public_folders%2FAll%2BReports%2BFolder%2FMaximo%2BReports%2FWO%2BCover%2BSheet%2FWork%2BOrder%2BPacket%2BCover%2BSheet%2Bv5
    This will be a Direct Print Report from the WO Tracking Application.
    What code do I need to add at the end of the link so the current WONUM will pass to the report?
    Something like %wonum=:wonum
    Thanks All!
    Maryann Wood
    Chelan PUD
  • 2.  RE: Cognos Report - Direct Print Report in WO Tracking - Report runs with Open WO
    Posted 04-12-2022 13:23
    I found the answer to this question - at the end - ParWoNum=:wonum
    Part II - This report has a Prompt Page, link is opening the Prompt Page - then user has to insert the WO #.
    How do I we send the Active WO # opened in WO Tracking to the Report - so the report opens with that WONUM?
    Do I delete the Prompt Page?
    Thank you. ​​​​
    Maryann Wood
    Chelan PUD
  • 3.  RE: Cognos Report - Direct Print Report in WO Tracking - Report runs with Open WO
    Posted 04-13-2022 09:34
    Edited by vineet joshi 04-13-2022 09:34
    Hello Maryann
    You cannot do Direct print from Cognos. Direct print is an icon in Maximo which prints the report(physically on paper) with/ out attachment. This functionality is limited to BIRT only.
    For your other question of passing the Maximo where clause, here is the link . Page # 50 and forward.
    https://www.ibm.com/support/pages/system/files/support/swg/tivtech.nsf/0/4c7448a75905562585257dee0055e6fd/$FILE/Maximo76CognosFeatureGuide_rev4.pdf
    Vineet
    vineet joshi
    Asset Analytix
  • 4.  RE: Cognos Report - Direct Print Report in WO Tracking - Report runs with Open WO
    Posted 04-13-2022 09:45
    Actually it does work!
    Yes, the Direct Print is an Icon in Maximo WO Tracking, we connect a link to the Cognos Report (in Cognos), to the Direct Print Report in Maximo.
    Then the user –
    • Opens Maximo WO Tracking
    • Clicks the Report Icon
    • And Opens the Cognos Report – in Cognos
    We are getting the link to work, Opens the Report, and the correct WO #, however, the first report we had a prompt page with a "Finish" button.
    • Report Opens for correct WO
    • But users must click "finish"
    I tried taking the prompt out, but I'm not having any success.
    Any assistance is appreciated.  Thank you.
  • 5.  RE: Cognos Report - Direct Print Report in WO Tracking - Report runs with Open WO
    Posted 04-13-2022 11:13
    Based on what I understood from your pervious comment, clicking on direct is not actually sending the report to printer it is opening up the report in cognos. This is more like a hyperlink from Maximo but not direct print
    For cognos prompt ,make it a not required field and it should not populate when you follow the process in the PDF I sent earlier.
    So if Maximo is passing the value in the where clause, cognos parameter should not show up . I have built several reports in the past where running the report from Maximo show the cognos report output directly rather than arriving on cognos parameter page
    Vineet Joshi
    vineet joshi
    Asset Analytix
  • 6.  RE: Cognos Report - Direct Print Report in WO Tracking - Report runs with Open WO
    Posted 04-26-2022 10:40
    I now have a report with "no prompts".  I also removed the Prompt for Value
    • Welcome Page
    • Action Menu
    • Properties
    • Report
    • Prompt for Values > Unchecked
    After I did this, I got a message "Report has no Prompts".
    When I tested to pass the link opening with a WO Number, I now am getting this error?
    "Data source adapter error:  java.sql.SQLException:  ORA-01489:  result of string concatenation is too long".
    Suggestions?
    Same link as I sent before, and we were getting the Prompt Page?
    Thanks.
    Maryann Wood
    Chelan PUD
  • 7.  RE: Cognos Report - Direct Print Report in WO Tracking - Report runs with Open WO
    Posted 05-02-2022 15:10
    Edited by Maryann Wood 05-02-2022 16:07
    FYI
    We got this link to work.  We are now passing the link for the Cognos Report via WO Tracking - passing the ACTIVE WO number.
    We needed to add the following extension to the end of the Cognos Report link - &p_ParWoNum=:wonum&prompt=false
    The Report link for reports can be found  - Action Menu > Share > Link.
    For testing - we replaced the :wonum with an actual WO number.
    Thanks.
    Maryann Wood
    Chelan PUD
