Hi Solution Experts,
Has anybody implemented SSO using SAML for Maximo Anywhere v7.6.3.1.
SAML based SSO for Anywhere apps needs 2 cordova plugins.
Steps given by IBM mobile first web page to manually install cordova plugins for Mobile first hybrid apps are not helpful/ basically not working.
The issue I am facing with those steps is that I need to make changes to a codova_plugins.js file which exists in the Assets folder of the apps. Now , problem is if I make any changes and try to build the apps then the changes are not committed to the built files. Reason being Maximo anywhere's build command clears the Assets folder and then recreates all the content of that folder from anywhere_plugin%.zip files.
I need to figure which zip has the cordova_plugins.js file so that new cordova plugins can be added to the apps.
Has any one installed cordova plugins in Maximo v7.6.3.1 or below?
I believe any cordova plugins installation will be same for Maximo 7.6.3 and lower versions.
Your inputs will be highly appreciated!
Biplab Das Choudhury
Biplab Choudhury
Tata Consultancy Services
