Hi Brian,
May be my answer is too technical but the first thing I would check is if Work center is able to connect with Maximo context.
You can do that from a web browser( preferable Chrome or Mozille) - use CTRL+SHIFT+I to open developer tool. Go to the console tab and reload the page. If you are getting $M is null error in the console then it means the work center is not able to connect with Maximo context which is defined in the config.json file( you already have done some checking there).
Here below is a good technote where the Work Center deployment is explained very well:
https://www.ibm.com/support/pages/deploying-maximo-work-centers-ldap-and-non-ldapThe above document will hep you understand the work center deployment very well.
Hope this helps!
Biplab
Biplab Choudhury
Tata Consultancy Services
Sent: 09-26-2020 10:15
Subject: Blank Page when logging into the Maximo Work Centers
Thanks Lacey. I did some research and I may need to configure the config.json and possibly the web.xml. Now it is somehow redirecting the primary maximo login to the maximo-x login.
Sent: 9/26/2020 8:04:00 AM
Subject: RE: Blank Page when logging into the Maximo Work Centers
Hi Brian,
Do you have all the security granted and are you only seeing this with the Work Technician and Work Supervision Work Centers? I had this same issue in a demo environment a few weeks ago. I'm chasing it down for you now. Someone else in this community may know the cause though.
Lacey Lurges
Sent: 09-25-2020 13:05
This may have been posted already, but did not find anything in a search, but I deployed the maximo-x war file on Websphere and I'm getting a blank page when logging in. I read somewhere that there may be some other configurations with config.json
files? Any advise would be much appreciated. Thanks
#WorkCenters
Brian Swanson
Herman Miller
