All Concerned:
I don't know if the resolution below will solve others encountering the same error message but it worked for my situation.
1. Since my configuration is LDAP, I ensured System Properties > Global Property
mxe.useAppServerSecurity = 1
2. In MxLoader, I set the Authentication to LDAP and entered my User and Password info. Next, I tested the connection which returned successful. I then executed a query and results returned without error.
I hope this information helps others.
Stevie
Stevie Holloway
U.S. Bureau of Reclamation
Sent: 06-27-2022 12:20
Subject: Microsoft Visual Basic - Run-time error '91' in Mx Loader 8.3.4
Has anyone found a resolution to this issue. I am encountering the same in MxLoader 8.3.5.
Stevie
Stevie Holloway
Sent: 05-17-2022 03:04
Hi Vikrant,
I have a similar issue, did you already find a solution to the problem?
Fred
Fred Aklamanu
Sent: 04-14-2022 14:02
When I try running the Mx Loader 8.3.4, I get the run-time error '91'.
Object variable or With block variable not set
I am able to establish a successful connection. I get this error when I run my Mx sheets for any operation. Any suggestions on what is wrong here?
Best Regards,
Vikrant K.
Vikrant Kushwaha
Savvy Logic Tech Consultants Corp
