Labor availability in Assignment Manager
  • 1.  Labor availability in Assignment Manager
    Posted 13 days ago
    I am working with assignment manager and have some labor codes that show negative available hours with no assignments. When I change the calendar associate with the labor code the negative available hours change based on the work hours on the calendar. When the same calendar is applied to other labor codes the available hours are correct. It does not seem to mater what date range I select the pattern remains the same. When I select view assignments the window shows none. It appears that somewhere there are assignments or something affecting the available hours. I have looked at the assignment table and do not see any entries for the affected labor codes. Any suggestions on where to look?
    Kevin Egolf
    TechOps
  • 2.  RE: Labor availability in Assignment Manager
    Maximo Certified
    Posted 13 days ago
    Did you check the person record to see of the work dates were modified? Action would be Modify Person Availability.
    this would cause the strange view in Assignment Manager where no work assignments are present:
  • 3.  RE: Labor availability in Assignment Manager
    Posted 13 days ago
    I did check that and there are no modifications to the calendar. The negative hours follow the same pattern regardless of the dates selected which seems to eliminate a spot change to the availability. This only seems to affect two of the labor records.
    Kevin Egolf
    kegolf@techopsolutions.net
    Director Asset Management Programs
    TechOp Solutions International
    Cell: 571-344-3221
    EMail logo SDVOSB
