  • 1.  Capture toggledetailstate event in auto script
    Posted 11-07-2022 12:13
    Team,
    i have a requirement, when ever a user clicks on View Details(which has mxevent has toggledetailstate ), i need to capture that userid and datetime and show that in a new tab on header level .That said, we want to capture the user who viewed the details and when in a separate tab. can we do that using automation scripts?
    pls advise
    Venkat
    Venkata Achanta
    CCSI
  • 2.  RE: Capture toggledetailstate event in auto script
    Posted 11-07-2022 14:03
    The toggledetailstate event itself you can't listen on with an automation script. You could replace it with your own automation script action event that calls toggledetailstate like:
    session=service.webclientsession()
    bean=session.getCurrentApp().getDataBean("common_task_table")
    bean.toggledetailstate(True)​
    I'm not personally a fan of this approach though. I'd rather force the user to acknowledge in some way rather than assuming them expanding a row is some sort of acknowledgement. IE have them click a button that says "I've reviewed this task" and then have that record an entry. Or if you want to record when they view something confidential, have a button that opens a dialog that records as part of the process of launching the dialog.
  • 3.  RE: Capture toggledetailstate event in auto script
    Posted 11-07-2022 14:49
    Thank you Steven for your reply, actually i told the user that i will add a check box in the more details section so that user can check that as Viewd. Then i will catch the history in a tab. But my user is not ok with that. pls see below screen shot on which i proposed.
    what i proposed was,
    1. user will expand the more details section first.
    2. set the Viewd flag to true.
    3. from there i captured the user details and other and displayed them in Log View History
    Venkata Achanta
    CCSI
