  • 1.  How to Call IBM outbox Java Function in Maximo Autoscript
    Posted 04-22-2024 18:49
    Edited by Eric Zuo 04-22-2024 19:35
    Dear experts,
    I need to write python scripts in Maximo to call action()  and getList() of psdi.app.workorder.FldWOJobPlan.class.   With customized java class, I can use super.action() and super.getList(). But How to do it in python auto script?
    First I may need to call the constructor FldWOJobPlan(MboValue mbv)  to create an instance.  I tried:
       supper = FldWOJobPlan ( curMbovalue )
       supper.action()
    It does not work. Could you please forward instruction?
    Thank you in advance.
    Eric
    Eric Zuo
  • 2.  RE: How to Call IBM outbox Java Function in Maximo Autoscript
    Posted 04-23-2024 09:16
    Eric,
    Generally I would just re-implement whatever the base class is doing so you have full control over it and in most cases the actions in a field adapter are pretty simple. With that said, you can do something like the following.
    from psdi.app.workorder import FldWOJobPlan
    def action():
        superField = FldWOJobPlan(mbo.getMboValue("ATTRIBUTE_NAME"))
        superField.action()
        # Do your custom actions here.
    action()
    You can take a similar strategy for the the get list and here is a blog post I wrote for reference on implementing lists with automation scripts.
    https://www.sharptree.io/blog/2022/2022-02-14-script-retrieve-list/
    Jason
    Jason VenHuizen
    Sharptree
  • 3.  RE: How to Call IBM outbox Java Function in Maximo Autoscript
    Posted 04-25-2024 13:43
    HI Jason,
    Thank you very much for your instruction.
    Eric
    Eric Zuo
