If Crontask gets stck and scheduled to run every 5 mins, will it reprocess the previous records?
  • 1.  If Crontask gets stck and scheduled to run every 5 mins, will it reprocess the previous records?
    Posted 04-14-2023 04:35
    I have created a crontask to process some images with a frequency of 5 mins. Suppose if out of 50 images only 40 got processed and 10 did not, will those ten and additional 50( second batch) get processed when cron runs after 5 mins( after the first run)?
    Please share your reviews
    #Analytics
    #Architecture
    #CivilInfrastructure
    #HSE/OilandGas
    #Infrastructure
    #IoT
    #LifeScience/Calibration
    #Linear
    #MaximoForAviation
    #Nuclear
    #Procurement
    #Scheduling
    #Security
    #ServiceProvider
    #Spatial
    #Transportation
    #Utilities
    #WorkCenters
    Deepa P
  • 2.  RE: If Crontask gets stck and scheduled to run every 5 mins, will it reprocess the previous records?
    Posted 04-14-2023 09:54
    Are you talking about an out of the box cron task or something custom? Generally speaking, a cron task will run to completion and the next one won't start until the first run is complete. For example, if you're configured to run every 5 seconds but it always takes 5 minutes to complete, Maximo will effectively only run the cron task every 5 minutes. You normally wouldn't run into a situation where 40 of 50 get processed unless you have an exception that causes the cron task to stop.
