Maximo REST API not performing write operations to DB in spite of 200 response code
  • 1.  Maximo REST API not performing write operations to DB in spite of 200 response code
    Posted 04-10-2024 22:26
    I am trying to update custom keys in workorder table (WO) via Maximo REST API. Specifically, I am making use of the /maximo/oslc/os/mxapiwodetail API endpoint to retrieve details using GET request and update using POST request.
    Below is the Python code which I use to achieve the same.
    import requests
    API_KEY = "<MY-API-KEY>"
    LOGIN_URL = r"https://<BASE-URL>/maximo/oslc/os/mxapiwodetail"
    header = {
        "apikey": API_KEY,
    workorderid = "<href-base64-value>"  # Example:  _VUZBL1dPMTAwMDAwNA--
    # `extstatus` and `sdlattdate` are the kays I want to update
    update_body = {
        "extstatus": "In Progress",
        "sdlattdate": "2024-04-11T00:00:00+12:00",
        "wonum": "<WO-NUM>",
        "externalrefid": "<ext-id>",
        "siteid": "<SITE-ID>",
        "orgid": "<ORG-ID>",
    resp = requests.post(
        url=f"{LOGIN_URL}/{workorderid}",
        params=update_body,
        headers=header | {
            'x-method-override': 'PATCH',
            'x-allow-events': "1",
            'x-public-uri': '<BASE-URL>/maximo/oslc',
            'patchtype': 'MERGE',
            'properties': 'workorderid,wonum,externalrefid,uffextstatus,uffsdlattdate,siteid,orgid',
    print(f"{resp.json()=}")
    The above request returns a 200 status code, however, the data is not updated both on the response JSON via properties option as well as on the Maximo UI.
    I am confident that the API call is made on the correct endpoint for this task as per the RESTful API swagger documentation page and I can see the keys from the API response via the `properties` header option, with the value being the older one and not the supposed to be updated one.
    I am also pretty sure that the base64 value passed via `workorderid` variable corresponds to the document I want to update since I can confirm it after decoding the base64 value which equals <SITE-ID>/<WO-NUM> for the document I am trying to update.
    Any help or suggestions in resolving this issue is much appreciated.
    Thanks in advance :)
    #Architecture
    #WorkCenters
    Harsh Kumaresan
  • 2.  RE: Maximo REST API not performing write operations to DB in spite of 200 response code
    Posted 04-15-2024 16:29
    I have finally figured out what the problem was.
    It was a problem with my Python code, where I have to pass the fields to be updated as json payload instead of as a raw dictionary body or as the POST request parameters. Also `lean` has to be passed as a URL parameter.
    For anyone struggling with a similar issue, here is what the complete Python code looks like:
    import requests
    API_KEY = ""
    URL = r""
    workorderid = r"" # Must be a `href` value from `GET` request. View Jason's comment for more info
    update_req_headers = {
      'accept': 'application/json',
      'x-allow-events': '',
      'apikey': API_KEY,
      'Content-Type': 'application/json',
      'properties': 'workorderid,wonum,externalrefid,extstatus,sdlattdate,siteid,orgid',
    payload = {
      "sdlattdate": "2024-04-15T00:00:00+12:00"
        url=f"{URL}/{workorderid}?lean=1",
        headers=update_req_headers,
        # data=payload
        json=payload
    Harsh Kumaresan
    Tuatahi First FIbre
